Old 02-27-2016, 10:43 PM   #1
52napco
1972 brake porportioning valve question please help
OK I lost my brake valve off the back of my rollback like an idiot. You would not believe how hard it is to find a replacement cast valve.... does anyone know what years will work on my 72 K10 ....thanks
52napco is offline   Reply With Quote
Old 02-27-2016, 11:37 PM   #2
swamp rat
swamp rat's Avatar
Re: 1972 brake porportioning valve question please help
You can buy new at Inline tube, a little pricy tho.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-28-2016, 12:05 AM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Last I looked brass replacements were available - maybe a WTB post on the parts board will help turn up a good used replacement cast piece.
Old 02-28-2016, 08:01 AM   #4
52napco
I bought a new one for $195 +$15 shipping only to be told several days later that they were
out of stock
Old 02-28-2016, 09:04 AM   #5
jocko
jocko's Avatar
LMC part 34-3200 - I bought that one - correct look and function replacement, worked fine. $225. I have not found a cost shortcut (i.e. a $99 valve). I would not go with a generic part from cpp, etc, personally.
Old 02-28-2016, 09:19 AM   #6
Grumpy old man
Grumpy old man's Avatar
Surely someone has 1 or more sitting in a parts tuck ,I'd hit up the 4wd guys .
Old 02-28-2016, 09:37 AM   #7
52napco
Thanks Jocko ill see if incan get one of those.
Old 02-28-2016, 10:06 AM   #8
52napco
That one is discontinued also......im hosed
Old 02-28-2016, 10:29 AM   #9
jocko
jocko's Avatar
oh noooo! Sorry, didn't know that. There's got to be another place that still has em.
Old 02-28-2016, 12:04 PM   #10
52napco
You would think someone would have them ..there has to something out there in cast tha
would work??? Don't want to go brass.
Old 02-28-2016, 03:14 PM   #11
swamp rat
swamp rat's Avatar
Inline tube, brass, about $85
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-28-2016, 04:24 PM   #12
ray_mcavoy
I think all the replacements nowadays are brass. So staying with cast is probably going to involve looking for a good used one.
The newer 73+ "squarebody" trucks use the same type of proportioning valve. It's mounted down on the front frame crossmember instead of up under the master cylinder.
I believe you'll want to look for one in the 73 through 77 range as those years had the same type of electrical connector for the warning light switch. 1978 & newer have a different style of switch connector. I think it can be changed out for the earlier style but you'd still need to find that part off an earlier valve.
And if I remember correctly, 71-72 had one front brake line exiting the prop valve that went into a Tee to split it left & right. While 73+ made use of the valve's 2 front outlets. So you may need a 3/8"-24 inverted flare plug to cap off one of the unused outlets.
ray_mcavoy is offline   Reply With Quote
