1972 brake porportioning valve question please help
OK I lost my brake valve off the back of my rollback like an idiot. You would not believe how hard it is to find a replacement cast valve.... does anyone know what years will work on my 72 K10 ....thanks
Re: 1972 brake porportioning valve question please help
You can buy new at Inline tube, a little pricy tho.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Carpe manana
![]() ![]() Join Date: Dec 2010
Last I looked brass replacements were available - maybe a WTB post on the parts board will help turn up a good used replacement cast piece.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
I bought a new one for $195 +$15 shipping only to be told several days later that they were
out of stock |
![]() Join Date: Oct 2009
LMC part 34-3200 - I bought that one - correct look and function replacement, worked fine. $225. I have not found a cost shortcut (i.e. a $99 valve). I would not go with a generic part from cpp, etc, personally.
![]() Join Date: Dec 2013
Surely someone has 1 or more sitting in a parts tuck ,I'd hit up the 4wd guys .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Thanks Jocko ill see if incan get one of those.
That one is discontinued also......im hosed
You would think someone would have them ..there has to something out there in cast tha
would work??? Don't want to go brass. |
Inline tube, brass, about $85
#12 | |
The newer 73+ "squarebody" trucks use the same type of proportioning valve. It's mounted down on the front frame crossmember instead of up under the master cylinder. I believe you'll want to look for one in the 73 through 77 range as those years had the same type of electrical connector for the warning light switch. 1978 & newer have a different style of switch connector. I think it can be changed out for the earlier style but you'd still need to find that part off an earlier valve. And if I remember correctly, 71-72 had one front brake line exiting the prop valve that went into a Tee to split it left & right. While 73+ made use of the valve's 2 front outlets. So you may need a 3/8"-24 inverted flare plug to cap off one of the unused outlets. |
