#526 |
Re: A 15 year old's project. Rusty 62 stepside
Also did some cleaning on the frame and got a bit of paint layed down. I used rustoleum black rust paint. It isn't sold in Canada because of how high the VOC content is so I had to get it in the states. It's very similar to por15 but a lot less expensive. It was used on my dads car a couple years ago and is still holding up good.
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#527 |
And I also finished making the cab corner so I welded it in and took the welds down. Lots of time in this one, at least it'll only need a skim coat of filler now that the metal is so good
#528 |
![]() Join Date: Mar 2013
Looking good buddy.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#529 |
#530 |
![]() ![]() Join Date: Jul 2002
#531 |
Cab corner looks great. Out of curiosity, do you use a 120v welder or a 220v? I am kicking around getting a 120v to do some body work and am wondering if it would be worth it.
'66 GMC K25 (305 V6, SM420) aka "Mabel" Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082 All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado |
#532 |
Thanks bill
Thanks Ben, I use a Lincoln 140 (110 volts) and it is more than enough for bodywork and I can weld up to 1/4" steal with good penetration. A 220 would only be necessary if you are going to be welding lots of 1/4" or thicker.
#533 |
These dust shields or whatever they're called that go under the cab corner on stepsides were very bend up but they had next to no rust. Here's before
#534 |
And 15 minutes later of hammering and grinding and they are nice and straight
#535 |
Today I worked on getting the shifter in the correct location so it won't hit the seat when down-throwing. I removed the shifter and cut it to a rabbet so that the two peices overlap. Then I drilled a hole and put a bolt through it then welded it all up. When cutting and welding I had to take breaks a lot and put water on it so that the plastic parts of the shifter didn't get too hot. Then I through some paint on it, greased it up and put it back in
#536 |
Then I cleaned up the shift lever and painted it. Angle of the picture makes it look shorter than it actually is
#537 |
Here it is all wrapped up
#538 |
shifter looks good , have you done the wheel well on second fender ?
any luck with the intake gasket ? |
#539 |
Thanks, no I haven't got around to the other fender as I've been taking a break from all the sheet metal work. As for the intake I'm waiting on a new gasket from the U.S. That should be better quality.
#540 |
Looking great. Are you planning on doing all of your own body work as well? Just wondering how you would go about prepping/working the cab corner. Do you primer, filler, primer, paint or filler, primer, paint?
#541 |
Looks nice!
#542 | |
Thanks tj
#543 |
I'm all about keeping trucks looking era correct, especially the interiors since it will never go out of style. I already have a era correct dash fan and radio that I have restored and today I rebuilt some under dash lights that I found that look like they are from the 70's that are really cool. The housings are stainless steel and the lens are tinted purple.
#544 |
Here is one of them lit up
#545 |
Cool!
#546 |
#547 |
Nice work as usual Nik. The purple lights are cool too.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
#548 |
Thank you Dale, I should have it ready to hit the road in a month or so
#549 |
Well Nik, I never even saw those before. I like them a whole load. Would love to know what they were from, and also to see how they were fitted in a previous life. Personally, the whole straw thing does it for me, which is why I always enjoy Marks thread on his truck, which constantly evolves. May have to look out for some of them. I have a pair of Blue Dots for my new tail light lenses that still need fitting when I get to that on my truck.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#550 |
,Those purple lamps are vintage,though till sold today.They are anti- glare windshield lamps for truckers.They mount up in the corners on the A pillar originally and lesson glare at night.
The Snortin' Bull |
