Old 04-16-2016, 04:09 PM   #526
62stepside longbox
62stepside longbox's Avatar
Re: A 15 year old's project. Rusty 62 stepside
Also did some cleaning on the frame and got a bit of paint layed down. I used rustoleum black rust paint. It isn't sold in Canada because of how high the VOC content is so I had to get it in the states. It's very similar to por15 but a lot less expensive. It was used on my dads car a couple years ago and is still holding up good.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 04-16-2016, 07:53 PM   #527
62stepside longbox
And I also finished making the cab corner so I welded it in and took the welds down. Lots of time in this one, at least it'll only need a skim coat of filler now that the metal is so good
Old 04-16-2016, 11:44 PM   #528
TJ's Chevy
TJ's Chevy's Avatar
Looking good buddy.
Old 04-17-2016, 12:39 AM   #529
62stepside longbox
Originally Posted by TJ's Chevy View Post
Looking good buddy.
It sure is! Thanks
Old 04-17-2016, 07:02 AM   #530
Old 04-17-2016, 12:17 PM   #531
BFoley
BFoley's Avatar
Cab corner looks great. Out of curiosity, do you use a 120v welder or a 220v? I am kicking around getting a 120v to do some body work and am wondering if it would be worth it.
'66 GMC K25 (305 V6, SM420) aka "Mabel"
Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082
All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado
BFoley is offline   Reply With Quote
Old 04-17-2016, 12:33 PM   #532
62stepside longbox
Thanks bill
Thanks Ben, I use a Lincoln 140 (110 volts) and it is more than enough for bodywork and I can weld up to 1/4" steal with good penetration. A 220 would only be necessary if you are going to be welding lots of 1/4" or thicker.
Old 04-17-2016, 03:49 PM   #533
62stepside longbox
These dust shields or whatever they're called that go under the cab corner on stepsides were very bend up but they had next to no rust. Here's before
Old 04-17-2016, 03:51 PM   #534
62stepside longbox
And 15 minutes later of hammering and grinding and they are nice and straight
Old 04-20-2016, 09:42 PM   #535
62stepside longbox
Today I worked on getting the shifter in the correct location so it won't hit the seat when down-throwing. I removed the shifter and cut it to a rabbet so that the two peices overlap. Then I drilled a hole and put a bolt through it then welded it all up. When cutting and welding I had to take breaks a lot and put water on it so that the plastic parts of the shifter didn't get too hot. Then I through some paint on it, greased it up and put it back in
Old 04-20-2016, 09:43 PM   #536
62stepside longbox
Then I cleaned up the shift lever and painted it. Angle of the picture makes it look shorter than it actually is
Old 04-20-2016, 09:45 PM   #537
62stepside longbox
Here it is all wrapped up
Old 04-20-2016, 11:44 PM   #538
60chevyjim
60chevyjim's Avatar
shifter looks good , have you done the wheel well on second fender ?
any luck with the intake gasket ?
60chevyjim is offline   Reply With Quote
Old 04-21-2016, 12:20 AM   #539
62stepside longbox
Thanks, no I haven't got around to the other fender as I've been taking a break from all the sheet metal work. As for the intake I'm waiting on a new gasket from the U.S. That should be better quality.
Old 04-21-2016, 07:14 AM   #540
BFoley
BFoley's Avatar
Looking great. Are you planning on doing all of your own body work as well? Just wondering how you would go about prepping/working the cab corner. Do you primer, filler, primer, paint or filler, primer, paint?
Old 04-21-2016, 10:09 AM   #541
TJ's Chevy
TJ's Chevy's Avatar
Looks nice!
Old 04-21-2016, 10:39 AM   #542
62stepside longbox
Thanks Ben, yes I am doing all the bodywork myself. I use filler at first then sand that down until the high spots in the metal reveal themselves then I do a very thin coat of filler if needed then sand downthen I move to the primer process, I spray with primer and then sand it to see if there is no more high or low spots. Once I know there's no high or low spots I use a product that is like self etching primer. I spray a coat down then hit it with high grit sandpaper and sand until I can just start to see the layer underneath. Then I spray some regular primer on and I'm ready for paint. Its and extremely time consuming process. I'm sure there are easier ways of doing it but I want it done right. You know what they say, " a paint job is 90% prep and 10% actual paint.
Looks nice!
Thanks tj
Old 04-22-2016, 10:37 PM   #543
62stepside longbox
I'm all about keeping trucks looking era correct, especially the interiors since it will never go out of style. I already have a era correct dash fan and radio that I have restored and today I rebuilt some under dash lights that I found that look like they are from the 70's that are really cool. The housings are stainless steel and the lens are tinted purple.
Old 04-22-2016, 10:38 PM   #544
62stepside longbox
Here is one of them lit up
Old 04-23-2016, 10:49 AM   #545
TJ's Chevy
TJ's Chevy's Avatar
Cool!
Old 04-23-2016, 03:32 PM   #546
62stepside longbox
Cool!
Thanks tj, you been getting any truck time in lately?
Old 04-23-2016, 09:11 PM   #547
65sub
65sub's Avatar
Nice work as usual Nik. The purple lights are cool too.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 04-24-2016, 12:46 AM   #548
62stepside longbox
Thank you Dale, I should have it ready to hit the road in a month or so
Old 04-24-2016, 02:22 AM   #549
Grizz1963
Grizz1963's Avatar
Well Nik,
I never even saw those before.
I like them a whole load. Would love to know what they were from, and also to see how they were fitted in a previous life.
Personally, the whole straw thing does it for me, which is why I always enjoy Marks thread on his truck, which constantly evolves.
May have to look out for some of them.
I have a pair of Blue Dots for my new tail light lenses that still need fitting when I get to that on my truck.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 04-24-2016, 11:57 AM   #550
namloc
namloc's Avatar
,Those purple lamps are vintage,though till sold today.They are anti- glare windshield lamps for truckers.They mount up in the corners on the A pillar originally and lesson glare at night.
The Snortin' Bull
namloc is offline   Reply With Quote
