Old 03-08-2004, 06:55 PM   #1
Bowed
For The Mechanics
Took my 77 out today and it ran fine with no trouble but when I was pulling into my garage ( this was my lucky day it happened there ) it started to sputter and then died .I then turned it over a few times but it would not fire and thinking it was the fuel pump (tank is full ) I primed the carb but this time it would not even turn over , just a click when the key was turned ( it has a new battery and the headlights were strong ) I let it sit for a few min then tried it again and this time it turned over but did not fire . I primed the carb once more but it just kept turning over with out catching at all , then after 4 or 5 tries it started and is running fine again . Would the nuteral switch on the clutch do this ? What electrical point could kill the engine and then make it turn over "intermittingly " both at the same time , maybe the ignition switch ? Any other ideas ?
Bowed is offline   Reply With Quote
Old 03-08-2004, 07:29 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I suspect your ignition switch is going bad if the battery has a full charge and you know you are getting fuel/spark normally.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-08-2004, 08:06 PM   #3
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I would look at the wire going from the solenoid on the starter to the HEI cap. A member on another board had that same problem and changed that wire out then fixed it.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
