Old 03-05-2004, 05:38 PM   #1
TIMSPEED
TIMSPEED's Avatar
[Pic] This is where my groundstrap should be right?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 03-05-2004, 05:45 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
yes
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-05-2004, 05:49 PM   #3
TIMSPEED
TIMSPEED's Avatar
ok...it's CUT, and I don't remember EVER cutting it, so HOPEFULLY when I replace it today, it will fix some of my small electrical problems....
See Them Here
Old 03-05-2004, 07:38 PM   #4
PHOENIX
Dont hook it to that spark plug wire
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 03-05-2004, 08:00 PM   #5
TIMSPEED
TIMSPEED's Avatar
hahaha, I know. I was just drawing that arrow to show that it connects to the back of that head.
See Them Here
Old 03-05-2004, 08:22 PM   #6
bigblock73
yeller
bigblock73's Avatar
Is that cork on your firewall??
bigblock73 is offline   Reply With Quote
Old 03-05-2004, 08:32 PM   #7
TwinTurbo
TwinTurbo's Avatar
Me thinks those little wire separators should mount on a bracket
TwinTurbo is offline   Reply With Quote
Old 03-05-2004, 09:40 PM   #8
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
Run a new Battery cable size ground from the starter to the frame.
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
Old 03-05-2004, 10:26 PM   #9
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
since we're nitpicking, who puts PCV on the passenger side? guh-heyyy
mike
mike reeh is offline   Reply With Quote
Old 03-05-2004, 10:28 PM   #10
bigblock73
yeller
bigblock73's Avatar
Is that a small twig or leaf jammed under the spark plug wires? :p
Old 03-05-2004, 11:25 PM   #11
1FaastC10
1FaastC10's Avatar
why not just bolt it to the head where its supposed to go? there are enough wires going to the starter to begin with, doesnt make much sense to add more. besides, grounding it to the starter, all you're really doing is grounding it TO the block THROUGH the starter.
Tim, it looks as if your assumtion is correct in the pic you posted.
1FaastC10 is offline   Reply With Quote
Old 03-05-2004, 11:55 PM   #12
TIMSPEED
TIMSPEED's Avatar
I do, cuz I have my Fresh Air thing on the drivers side, AND my PCV Port is on the passenger side of my carb...
See Them Here
Old 03-05-2004, 11:56 PM   #13
TIMSPEED
TIMSPEED's Avatar
No, a piece of sandpaper. Hahaha, my dad put it there when the firewall rusted a hole around the heater core, and since this was HIS truck and he died, I WILL NOT remove that jerry-rig fix. Sorta, keeping his touch on the truck.
See Them Here
Old 03-06-2004, 01:01 AM   #14
toytruck
toytruck's Avatar
[QUOTE]Originally posted by 1FaastC10
[B]
Well Gee. You got this big pos batt. cable going to the starter wouldn't you want a nice big ground cable there too. Makes your starter roll over alot better.
Old 03-06-2004, 03:00 AM   #15
ocbaud
Garage Queen Material
where should i run my ground strap since i have alum. heads?
ocbaud is offline   Reply With Quote
Old 03-06-2004, 03:06 AM   #16
toytruck
toytruck's Avatar
electricity still flows through alum.
Old 03-08-2004, 06:05 PM   #17
PHOENIX
Damn all them comments had me rolling.
BTW: Did you get the strap installed?
Mine looks pretty nasty from all the oil that has leaked on it in the past. Can you buy them new from the dealer? Are there different lengths? How much do they cost?
Old 03-08-2004, 08:30 PM   #18
TIMSPEED
TIMSPEED's Avatar
I got a new one from Napa Auto Parts for $6, they had 12", and 18" lengths...trust me, GET THE 12"!
See Them Here
Old 03-08-2004, 09:13 PM   #19
1FaastC10
1FaastC10's Avatar
since when the starter is bolted to the engine, the entire mounting face of the starter is its ground, you're just as well off to put it where it belongs. you're not going to get any noticable gains by putting it directly on the starter. not to mention making the starter easier to remove/replace in the future, and routing the cables is 100x easier. ever had to replace your positive cable? its a b!tch to say the least.
Old 03-08-2004, 10:32 PM   #20
1985K10
1985K10's Avatar
True...Aluminum conducts electricity much better than steel, most over-head power lines are aluminum.
Anthony
07 Tahoe LT
70 Chevelle 450HP 383-TH400
77 GMC Royal Sierra~Resto in progress~
1985K10 is offline   Reply With Quote
Old 03-08-2004, 11:08 PM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
I thought it was a piece of a roofing shingle.:p
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-08-2004, 11:41 PM   #22
corn
A good heavy flat braided ground strap from the frame to one of the bell housing bolts will work better than using an insulated cable & having it melt against the headers...corn
corn is offline   Reply With Quote
Old 03-09-2004, 12:08 AM   #23
The Dude
so did the ground strap fix your problem?
The Dude is offline   Reply With Quote
Old 03-09-2004, 06:53 AM   #24
TIMSPEED
TIMSPEED's Avatar
Good Eye Ken! That's actually what it is!
See Them Here
Old 03-09-2004, 06:54 AM   #25
TIMSPEED
TIMSPEED's Avatar
Didn't seem to make a difference, no. But at least I know THAT'S not my problem now, so one less thing to worry about.
See Them Here
