#101 | |
![]() Join Date: Mar 2013
Re: 1966 C10 Project Truck
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#102 | |
#103 |
Didn't get a whole lot of time to work on it over the weekend but I was still able to find a little each night. My steering showed up on Friday, gotta say that this is probably one of my favorite pieces on the truck. I can't wait to drive it! It's the rack and pinion kit from Unisteer, simple to bolt on the only thing that would've been nice was to have specific instructions for the 60-66 trucks. It still went together smooth though.
![]() No turning back now! ![]() Saturday, I got my air cleaner back from dad. All he did was clean it up, didn't need paint! ![]() I also was able to get the front sway bar on after the Mother's Day festivities yesterday. It's coming together ![]() ![]() ![]() Still waiting on my brake and fuel lines. I'll give Classic Parts a call tomorrow if I don't see them tonight. |
#104 |
Looking good!
#105 |
Kind of in a dilemma with the radiator. I dropped it off yesterday to get checked out and fixed as needed and they called me back today. It's got good flow and holds pressure but it is showing it's age with a bowing core and some degradation of the tubes. I plan on pushing the truck somewhat hard in an autocross type setting but not terribly hard when I'm just driving it. I'm thinking I'll slap it in and run it until it quits being a radiator, hopefully it outlasts the motor. Sorry I-6 guys, this will have a V8 before too long.
Re-coring is more than a replacement (bummer since mine is original) and a new radiator runs about $360. What do you guys think, will I be ok through the summer or should I replace the radiator while I'm here? |
#106 |
Here ya go:
http://www.ebay.com/itm/1963-1964-19...3D291522805303 Have you considered hopping up the 292? Little spendy, but a rather fun journey.
#107 | |
I haven't put much thought into hopping up the 292. I know it's a great motor but the plans and goals that I have (need 120-140MPH with ease), it would take way more money than if I were to swap in an LS. Plus, I really am not keen on the sound of the old inlines, just doesn't do much for me. |
#108 | |
#109 | |
Either way, it'll be a badass little truck with an LS and a T-56 ![]() |
#110 |
Well, I took a few days off for some last minute preparations for Oregon Trophy Challenge. It's an offroad event that I've competed in in my Jeep and this year helped organize. It was a ton of fun but it's time to get back to the Chevy!
Didn't do a whole lot last night but I did get the fuel line on and a few other little things done. Going to work on the brake lines and water pump tonight ![]() |
#111 |
Things to do while waiting on brake line fittings. Got the rear driveline on, the correct water pump on, plumbed the fuel line from the tank to the pump and changed out the driver's side window track. I need to do a bit of tweaking with the driveline as it's biased towards the passenger side a bit but other than that it's coming together nicely.
![]() ![]() I also carried the 250 valve cover over since it has Chevrolet on it and the 292 didn't. I searched high and low for the valve cover grommet that holds the tube to the air cleaner. Chevy didn't have it so I got an expandable freeze plug. Not pretty but functional and doesn't look too ugly either. ![]() I will have my brake line fittings today when I get home. Tonight I'm headed to PIR for a track night to watch my buddy run his F100 and get some exposure to this new world I want to play in. Should be a great time! |
#112 |
Got a bunch more progress made over the weekend. I'm starting to realize I more than likely won't have it fully ready to go for the show on the 11th but I should be able to drive it on and off the trailer so that's ok. Not for lack of trying, it's just how it goes.
My buddy came over Saturday night and we plumbed the brake lines and the fuel line from the pump to the carb. ![]() ![]() ![]() Sunday morning, I tore right into it and removed the factory radiator mounts. The radiator I picked up needed a 3" rise to get the height I needed, it'll work great ![]() ![]() ![]() ![]() While I was fabbing up my riser, dad showed up and got to work on my tranny cross member. We had to slot the holes so the output could be pushed to the driver's side a little more. Once that was taken care of, I clearanced the frame a bit for my steering shaft for the rack. Way better now. ![]() Rear sway bar going on ![]() One thing that I knew was going to hold this whole show up was the accessory drives. I have been struggling to find the right water pump pulley and also the brackets that will bolt the power steering pump to the engine bracket. I found those things last night! Cost a bit more than I'd like but they are what I needed so it's not too bad. ![]() More work will continue this week and into the weekend! |
#113 |
Nice rad! And great job finding the pulley!
#114 |
Thanks! It's a Northern Radiator. Baxter's had it sitting in the warehouse for who knows how long
![]() Got the rear sway bar on last night and started mocking the engine stuff up. It's starting to look like something ![]() ![]() ![]() I ordered a turnbuckle so I can tension the power steering belt, I should have that tomorrow night. I may make a bracket that bolts to the pump for the turnbuckle but I'm not sure yet. Gotta see how it all lines up first. ![]() ![]() ![]() Not sure if I'm digging the chrome bracket or not, I'll have to see how long before it bugs me and I paint it black ![]() |
#115 |
It's got brakes, woo hoo!
#116 |
Looking exceptionally good.
I have radiator envy.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#117 |
Thank you!
The radiator was surprisingly cheap, just a bit over $200. It's from Northern and is P/N 209676 for those that might be interested. The factory upper hose works pretty well but the lower does not, easy fix though ![]() |
#118 |
#119 |
Were you shocked by their present?
Couldn't resist . . . Happy birthday btw from a fellow Oregonian. You're not far from me (I'm in the Forest Grove area). Would love to check out your build sometime. |
#120 | |
![]() I've been keeping an eye on your build too, I like it! I'd love to check it out sometime ![]() |
#121 |
Shoot me a PM if you're ever going to be in the FG area. Always welcome to stop by and check it out
#122 | |
![]() I got the chance to work on the truck all weekend. While I didn't get to make progress on the things I wanted to, I was able to hammer out a bunch of little things that had popped up and I did get to hear it run! I still have to tinker with the alternator bracket and build my power steering adjuster bracket before I can run it for longer but hearing it run was definitely awesome! Work was a little slow on Friday so I was able to break away from my desk for a few and hammer out the pieces I needed to hook my clutch pedal up to the master. ![]() I had tapped one of them to 5/16-18 but needed 5/16-24, doh! I actually cut a section of the factory panhard bar to remake it, worked slick! ![]() Linkage shot ![]() Pedal is right in line with the brake pedal, much better for me ![]() ![]() The lower radiator hose put up more of a fight than I thought. I spent easily half the day on Saturday just trying to find one that worked. Thought I had it but when I got home, it still didn't work. I had some 1.75 tubing laying around from an old project and had the perfect bend in it. Lucky! ![]() Finished up, looks great! I did run a weld bead around each end to create a lip so the hoses don't slip off later. ![]() Got the shocks on ![]() Sunday night, I pushed it out of the garage to give it some fresh air and make room for the bed pieces. This is the first time it's been outside since March! ![]() ![]() I did get a wild hare and fired it up too. I didn't have the belts on it so I only ran it for a short time. It seems to run great! https://www.youtube.com/watch?v=3e9-tnDUMeo Yesterday, I worked on the bed and dad came by to help troubleshoot the clutch. He fixed some of it but it appears that the throwout bearing isn't 100% correct on the shift fork so looks like I get to pull the tranny and fix that. Bed wood turned out great! I wish it had the holes in it but that's also looking like why this kit was cheaper than anywhere else. No biggie. ![]() |
#123 |
Looking real good!
#124 |
Nice work, your sure getting a lot done
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#125 | |
Thanks! Being single does have it's benefits sometimes ![]() |
