Old 03-11-2004, 08:26 PM   #1
tandm1999
front suspension help
does anybody know or has any body swapped an early 60's front cross member for a late 60's early 70's front suspension and cross member
im wondering if the cross member from a 1962 will interchange with a crossmember from 1970 any info would be appreciated
tommy
tandm1999 is offline   Reply With Quote
Old 03-13-2004, 09:15 AM   #2
mxman
hi
do you have a late 60s xmember ? why not just use a 73-87
mxman is offline   Reply With Quote
Old 03-13-2004, 12:18 PM   #3
SCOTI
SCOTI's Avatar
Yes... any front cross member from late 60's thru 87 will interchange. When using a c-member from the 73-ups, there are a couple of holes in the frame (one on each side) that require 'ovaling' to be able to get the bolts in. The disc brake c-members typically have the larger u-bolts (9/16" vs. 1/2") for mounting the lower control arms & are stronger (plus you can use the late model control arm rubber bushings for a better ride).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-13-2004, 01:12 PM   #4
tandm1999
i have a 72 3/4 ton xmember with 8 lug disc brakes
tommy
Old 03-13-2004, 02:38 PM   #5
SCOTI
SCOTI's Avatar
Is the crossmember from the 70 3/4 ton going to a 62 3/4 ton frame? I believe the 3/4 ton frames are different (taller) than 1/2 ton frames.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-13-2004, 04:33 PM   #6
tandm1999
yes i have a 62 3/3 ton gmc pickup that i want to put the 72 3/4 ton xmember on
tommy
