Old 11-08-2015, 10:29 AM   #126
KrazyRay
KrazyRay's Avatar
Re: Another 4X4 Front Sway Bar
Yes. Sending pm...
KrazyRay is offline   Reply With Quote
Old 11-27-2015, 08:10 AM   #127
69_hafton
Sleep-Deprived
69_hafton's Avatar
I'd like one also if you have one; 74105
69_hafton is offline   Reply With Quote
Old 12-04-2015, 07:29 PM   #128
KrazyRay
KrazyRay's Avatar
Sold and shipped to halfton...Thanks!
Here's another one available. Its in good shape, but there are some small scars from it being welded to the frame. $90 plus shipping.
Old 01-08-2016, 10:55 AM   #129
69_hafton
Sleep-Deprived
69_hafton's Avatar
Bump for your thread - Thanks again for providing these for sale - it can't be too easy removing them from the trucks they come off of.
Installed on truck with a 6 inch lift. If I ever have the front clip off, I'll make a couple of adjustments to the install. Had to remove the fan and radiator to drill 2 of the holes and only used 2 spacers under top mounting points of the frame so you can't see them.
1971 K/10 Long Fleetside
350/350 - 6" Lift
1969 C/10 SWB 292 - Sold It
Old 01-09-2016, 11:27 AM   #130
KrazyRay
KrazyRay's Avatar
Looks nice! It looks like you moved the cross member back a bit to line up with the 6" lift. Thanks for posting up the pictures.
Old 01-09-2016, 05:33 PM   #131
69_hafton
Sleep-Deprived
69_hafton's Avatar
Thanks, I used the factory rivet holes in the bottom of the frame and drilled new holes in the top of the frame that moved the mounting points about 3" back from the factory rivet holes in the top of the frame. The replacement cross member has 2 holes on either side and comes to a sharp point that gets in the way for this install. Removed the point and one mounting hole to help with installation. If I had the truck apart, I could be more precise with the new mounting holes in the frame, but as it went, took using c-clamps and pry bars to get it to set in place and lined up. Hopefully this will help anyone else consider doing this - I just like the more factory look of this set up compared to the aftermarket bars that are out there.
350/350 - 6" Lift
Old 07-01-2016, 01:05 AM   #132
KrazyRay
KrazyRay's Avatar
ttt 1 still available
Old 08-14-2016, 01:54 AM   #133
PDXk5
PDXk5's Avatar
KrazyRay,
Do you still have one complete set up available? I would prefer one without the weld marks you make reference to for the last one posted. Shipping will be to 97217.
Thanks!
PDXk5 is offline   Reply With Quote
Old 08-15-2016, 07:05 PM   #134
KrazyRay
KrazyRay's Avatar
Yes, I have one without the weld marks. $125 shipped to OR.
Thanks,
Ray
Old 08-20-2016, 10:08 PM   #135
PDXk5
PDXk5's Avatar
Ray,
Sway bar assembly came today. Looks great, thanks !
Old 08-22-2016, 10:21 AM   #136
Tdrcreyn4
Tdrcreyn4's Avatar
Any left? I'll take one of the set ups if you do.
1968 C10 292/3 spd - sold
1969 K10 350/3 spd/205 - sold
1971 K5 350/4 spd/ 205 - sold
1970 K20 350/350/205 - sold
1969 K20 396/400/205 - work in process
Tdrcreyn4 is offline   Reply With Quote
Old 08-22-2016, 10:26 AM   #137
cmabolt
cmabolt's Avatar
Please put me in line for one of these.
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636
Easier to beg forgiveness than ask permission!
cmabolt is offline   Reply With Quote
