Old 03-20-2013, 12:46 AM   #1
KrazyRay
KrazyRay's Avatar
Another 4X4 Front Sway Bar
EDIT: I HAVE 1 AVAILABLE AS OF 1-23-15 These sway bars are a great improvement to the handling of your 67-72 4wd truck, blazer, suburban. You will need to remove your front crossmember and install this one which is equipped with the brackets to mount the sway bar to. The kit includes the sway bar, the spring plates for attaching the bar to your leaf springs, and the front crossmember. You will need new bushings (Napa auto parts), and some grade 8 bolts. This one is in nice shape and I will remove the shims that were used for the 6" lift that this came from. NOTE: It may require grinding 1/8" on the u bolt plates if the axle tube is 2.75" diameter.
$90 plus shipping. Shipping will cost between $32-$48. Post office money order or paypal...you cover fees.
Thanks,
Ray
KrazyRay is offline   Reply With Quote
Old 03-20-2013, 08:23 AM   #2
POS1
Re: Another 4X4 Front Sway Bar
PM sent - I'll take.
- Brian
FleetFilter.com
1991 Chevrolet V1500 Suburban 4x4
1986 Jeep CJ7
1969 Porsche 911S Targa
POS1 is offline   Reply With Quote
Old 03-20-2013, 09:33 AM   #3
2003 silverado
2003 silverado's Avatar
2nd In-line if it dosent work
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
Old 03-20-2013, 03:27 PM   #4
KrazyRay
KrazyRay's Avatar
Sold to POS1 pending payment. Thanks!
2003 silverado, I will have another one soon and let you know.
Thanks,
Ray
Old 03-30-2013, 05:54 PM   #5
2003 silverado
any luck on a second one??
Old 03-30-2013, 10:28 PM   #6
KrazyRay
KrazyRay's Avatar
Its on a truck that I need to take apart. Usually, the sway crossmember is the last thing to be removed. I will try to speed it up.
Thanks,
Ray
Old 03-31-2013, 04:18 PM   #7
2003 silverado
Thanks ray just let me know (no rush)
Old 04-26-2013, 08:57 PM   #8
KrazyRay
KrazyRay's Avatar
I pulled a 4x4 sway bar today. pics coming soon...pm sent
Old 04-28-2013, 10:44 AM   #9
KrazyRay
KrazyRay's Avatar
I still have to remove the crossmember from the frame horns and there are some "chatter marks" possibly from a flex fan launching that will clean up easily with a flapper disc on an angle grinder. Otherwise solid and in good shape.
Old 04-28-2013, 11:35 AM   #10
mesracer
Please put me in line for sway bar. Thanks.
mesracer is offline   Reply With Quote
Old 04-28-2013, 03:54 PM   #11
2003 silverado
Ray Pm me your Info for paypal . I will add the paypal cost also Thanks Ray
Old 05-01-2013, 11:05 PM   #12
KrazyRay
KrazyRay's Avatar
Sold to 2003 silverado...Thanks!
mesracer...I should have another in about 2 weeks.
Old 05-02-2013, 12:20 AM   #13
BlazerTime
What year trucks are these from? My Blazer has a bar that looks Ike this but I need bushings and not sure what application to ask for?
Thanks.
Jeff
BlazerTime is offline   Reply With Quote
Old 05-02-2013, 09:10 AM   #14
KrazyRay
KrazyRay's Avatar
These are from 73-87 trucks.
Old 05-02-2013, 09:43 AM   #15
BlazerTime
Thank you. Do you ever come across just the cross member? Is the cross member the same on a truck that was not optioned with a sway bar? Whoever put the one on my truck did not use the cross member, they created some bracket mounts. It works ok just not real pretty and this. May be something I want to clean up.
Thanks again.
Jeff
Old 06-10-2013, 10:50 AM   #16
KrazyRay
KrazyRay's Avatar
The crossmember is the toughest part to get because it requires cutting up a frame and they are specific to the sway bar. I have another sway bar setup available. mesracer is first up.
Thanks,
Ray
Old 06-17-2013, 12:12 AM   #17
Crash_OK
Crash_OK's Avatar
Ray,
Please put me inline for one of these...
Thanks..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 06-17-2013, 02:00 AM   #18
KrazyRay
KrazyRay's Avatar
Originally Posted by Crash_OK View Post
Ray,
Thanks..
pm sent
Old 06-17-2013, 09:07 PM   #19
Crash_OK
Crash_OK's Avatar
Originally Posted by KrazyRay View Post
pm sent
Payment sent...
Mark
Crash's 69 4x4 SWB
Old 06-22-2013, 10:28 AM   #20
KrazyRay
KrazyRay's Avatar
One more available!
Old 06-22-2013, 10:43 AM   #21
rustyrexiusrodz
i'll take it if you have another one
olyhotrodz
rustyrexiusrodz is offline   Reply With Quote
Old 06-22-2013, 12:44 PM   #22
KrazyRay
KrazyRay's Avatar
pm sent
Old 07-05-2013, 02:11 PM   #23
KrazyRay
KrazyRay's Avatar
I have another one available!
Old 07-05-2013, 11:51 PM   #24
Evan68chevy
I would be interested. Can you send me some pictures? Would it have the front cross member like the last ones?
Thank you
Evan
Evan68chevy is offline   Reply With Quote
Old 07-06-2013, 12:40 AM   #25
swamp rat
swamp rat's Avatar
EDIT: I HAVE ONE AVAILABLE AS OF July 5th! These sway bars are a great improvement to the handling of your 67-72 4wd truck, blazer, suburban. You will need to remove your front crossmember and install this one which is equipped with the brackets to mount the sway bar to. The kit includes the sway bar, the spring plates for attaching the bar to your leaf springs, and the front crossmember. You will need new bushings (Napa auto parts), and some grade 8 bolts. This one is in nice shape and I will remove the shims that were used for the 6" lift that this came from.
$90 plus shipping. Shipping will cost between $30-$45. Post office money order or paypal...you cover fees.
Thanks,
Ray
Obviously i'm late on this and that's ok, i have a couple questions, never seen this before wanted to ask will this only work with stock height suspension? I have a 4" lift so wanted to know if it would work for me if i ever run across another?? Thanks!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
