Old 07-10-2016, 01:30 AM   #1
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
Anyone running 15x12 rims on a 68 stepside?
What size tires? Any pics?
I can widen the fenders if needed
Thanks,
Dave
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 07-10-2016, 12:30 PM   #2
72 K20
72 K20's Avatar
Re: Anyone running 15x12 rims on a 68 stepside?
I have 15 x 12 welds on a 72 short fleet side. Do you have coils or leaf springs ? The tubs have been widened. These wheels on the rear have 8" backspacing. The tires are 13x28 x 15 street slicks. There is clearance between the trail arm and the inside of the wheel ,,, I think I could actually run a 9" back space if I would modify the bracket that holds the E-brake cable . Then maybe go with a 14" wheel ! LOL !
72 K20 is offline   Reply With Quote
Old 07-10-2016, 03:14 PM   #3
Possmguts
Possmguts's Avatar
No frame mods for those fat tires? I was under the impression you couldn't do more than maybe a 5 inch back space on a 10 inch wheel on the fleet side... If you was able to do it then Ill be going wider myself...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 07-10-2016, 03:37 PM   #4
WinDancer
WinDancer's Avatar
Thanks, K20. Cool truck!
I had been torn between 10s and 12s. Seeing your truck from the back convinced me to go with the 12s. What do your tires read on the side walls and what brand?
I replaced the leaf springs with new coil overs and 4 bar with pan hard.
Any other pics out there? Please do tell us the tire size and brand.
Thanks again
Dave
Old 07-10-2016, 08:52 PM   #5
72 K20
72 K20's Avatar
My truck has coil springs ,,, I don't think you can fit that offset on a leaf spring truck. The angle of the trail arms allows the deep back spacing. With leaf springs running parallel with the frame I don't know if they would clear . The tires are M/T ET street slicks. 28x13.5x15 .
