Old 08-10-2016, 05:49 AM   #26
Re: Hi flow catalytic converter
Originally Posted by wbc409 View Post
Catalytic converters don't work right until they get hot. I was instructed when I was younger not to put cats on a vehicle that wasn't originally equipped because of a lack of heat shielding and the possibility of starting the carpet on fire. I imagine this would be more of a problem with a carbureted engine. Also if the engine runs rich it will ruin a cat fast.
That is true about needing to be hot to work. But, they wouldn't be under the cab on these trucks and would hang below the bed plenty enough to eave room for a deflector. Of course, a cat located so far back would not see enough heat, either. The whole idea of using cats in place of mufflers for sound is a failed concept on these trucks. After mufflers will be hotter also, just as they are in OEM applications. There are so many choices in mufflers, you can tailor your sound in a variety of ways... or run straight pipes!
Old 08-10-2016, 09:29 AM   #27
farmsweet
OK..OK..I get it now ...thank you all for your replies and the great pics. I realize now that its kind of stupid to put these on an older truck as they do nothing for the sound, which is why I though of putting them on in the first place.
farmsweet is offline   Reply With Quote
