Old 12-20-2012, 06:46 PM   #1
farmsweet
Hi flow catalytic converter
Any one running a hi-flow catalytic converters? I'm thinking of putting a pair on my 71 468cu and was wondering if these would quiet the exhaust down. currently I have 3" exhaust pipes off the headers to summit mufflers ,then turned down and out and I know I'm going to have to change them out for quieter ones cause it sounds like a gasser right now.
farmsweet is offline   Reply With Quote
Old 12-20-2012, 07:28 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Hi flow catalytic converter
I'm sure Summit ,PAW or another of the online/mail order places has them.I see no reason to run them on one of these trucks.They aren't required by law and you'll probably get better sound with the right mufflers(meaning ones you like the sound of).There's noperformance or emmisions gain,that I'm aware of.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-20-2012, 08:27 PM   #3
skorpioskorpio
Umm, why would you put a cat on? If you were running a modern LS engine with TPI or something I might understand trying to be environmental about it all but you're running a 468ci, big block I assume, carborated I would guess. I'm not even sure that without the rest of the carb era emissions junk to go along with it that a cat will even last, if it is carburated. I think you should be looking at resonators instead of trying to use a cat as one.
skorpioskorpio is offline   Reply With Quote
Old 12-20-2012, 08:33 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
A cat won't quiet the exhaust down. With an engine like a 468... it's built to make power. Which is gonna make some noise. Cats are just gonna choke that thing down.
All the popular aftermarket companies make good sounding "quiet" mufflers. Again... when you have an engine like that... you should be prepared for some cab reverb. run the exhaust all the way out the back and use an "H" or "X" pipe... you'll notice a big difference.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-20-2012, 08:40 PM   #5
leftybass209
leftybass209's Avatar
A cat is not like a muffler, as it isn't designed to muffle the sound. I would applaud anyone wanting to put a cat on their vehicle, though most people think the idea is obsurd. You really should be looking into different diameter pipes, quieter mufflers, and an h or x pipe if noise is the factor. Exhaust manifolds help also.good luck in your search!
leftybass209 is offline   Reply With Quote
Old 12-21-2012, 08:11 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Gary
The cat will significantly quieten an exhaust. Think back a few years when all the guys with hot rod 5.0L Mustangs used to run an "off road" pipe under them. You could tell from a long way away if a guy had removed the cats or not. Quite profound.
Old 12-21-2012, 08:18 AM   #7
MARKDTN
On my '83 K20 wuth TPI I run dual exhaust with Walker high-flow cats and no mufflers. The sound is not that nice. I don't do it for sound reduction, I do it because I have to have them. No way I would have them except they are required.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-21-2012, 08:52 AM   #8
Tx Firefighter
You do have some easy options.
In my case, I have to run a catalytic converter under my dually to pass a visual inspection. There are no functional tests, but it has to be under there when I get my yearly safety inspection. So, a quick Google of "fake catalytic converter" led me to a company in Colorado that sells them in all sizes, and cheap. You're looking at 40 dollars here for a straight through pipe. Mine is 3 inch, but you can choose your size you need from their selection.
I won't go too far into the argument of legality, but it does look like a converter to the eye but it's a smooth straight through pipe inside the case.
Old 12-21-2012, 09:34 AM   #9
midniteblues
midniteblues's Avatar
those hollow converters are cool most guys around here make there own but there never that nice.
I had too put'm on the camaro too get it legal but once it was they were instanly replaced with 3" . I had the system made up with collecters so I could do this easyly and I must say that there definitly was a noticeable sound and flow differnce (I used the magna flow high flow connverters)you could really tell the differnce with revs it would wind up a lil' slower and tend too hover or float in the higher revs just a tad.
after they were off the cat was outa the bag! and it winds up and down with the blip of the peddle.(i'm assumeing this was because of the extra back pressure)the cam didnt sound as lumpy with them on either, the car just flat out loves it without them so do I it sounds sooo much better
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 12-21-2012, 09:39 AM   #10
I had a '90 Blazer w/350 that had to go through emission. I ran dual exhaust and used two Thrush hi-flow cats. They restrict flow less than a muffler,you can look straight through them. I gave thought to running them on my old trucks,but haven't yet. Why not attempt to help keep the atmosphere cleaner? We do lot of things we "want to" that we don't "have to",like putting shoulder belts in these trucks. I guess I care beyond my own well being. I understand it from an economic stand-point,not spending money you don't have to spend. I've cheated on emissions equipment for economic reasons myself. I had a '99 ZR2 that has three cats. Two "eggs" on the y-pipe and the big one in the single. They were getting all clogged up,truck was running bad,and throwing a code. The "eggs" are not replaceable. You have to buy the whole head-pipe assembly and that was like $700. How much do those tiny things do anyway? One night at my buddy's repair shop we torched them out and reamed the main one out. You don't need to buy anything. It still passed emissions,which is a dyno test taken from the tailpipe. So,there's enough tolerance that cats don't really matter.
Old 12-21-2012, 10:09 AM   #11
midniteblues
we did this too a 92 blazer and the o2 sensor (even a new one) allways put up a code we thought because it never got hot enough after the hollowing of the cat?
Its funny you said this I've been thinking of hollowing the ones on my
2000 zr2 but I didnt want the same problem we had on the blazer.
after you did it did you notice any improvements? mpg's? seat of the pants?
they dont do the tail pipe up here just a gas cap test and puter check for codes
Old 12-21-2012, 10:16 AM   #12
Tx Firefighter
I do understand the moral issue of doing what is right.
I kind of got disheartened when I had my 89 model truck. When I got it, the previous owner was from a non tested county so he removed the air pump stuff from the truck. When I got it, I went ahead and really removed it, meaning I made it appear that the truck never had a smog pump originally. I plugged the manifolds, removed the old brackets and everything. Funny thing is, it still legit passed the of sniffer test by a mile without all of the factory smog stuff (just a TBI 350 with a good cat in the exhaust. I was thinking that I was glad I didn't spend a bunch of time and money to make it all back proper. The emissions stuff is about 50 percent bunk anyway.
On my current 88 dually, it has a TBI 454 and no overdrive and 456 gears. I drive it maybe 1500 miles a year. No more than I would pollute with that little bit of use, I just don't worry about it.
Some government stuff is okay but some is a little too much. I walk a line that lets me sleep at night.
Old 12-21-2012, 10:22 AM   #13
c10srule
c10srule's Avatar
run 2.5" pipes with quieter mufflers, wouldnt go any smaller or it will start hurting the performance on that big motor, makes no sense to put cats on the old tuck, like mixing oil with water
c10srule is offline   Reply With Quote
Old 12-21-2012, 10:24 AM   #14
c10srule
c10srule's Avatar
and like said run them all the way out the back, that itself will make a big difference in the cab noise, turn downs are loud inside the truck tried it when i first got my truck going, they werent that way for long
Old 12-21-2012, 12:02 PM   #15
PanelDeland
As far as cats.legality and inspections go.Hot Rod(IIRC) did a story a few years ago.It wasn't specific to cats but was about emmisions.They had built a new engine and got it in the car,tuned and running nice.When they took it for emmisions testing it passed with great numbers.When they popped the hood,it failed on visual inspection because some of the emmisions equipment was missing.Then they took it back to the shop,installed the missing emmisions stuff and had to slightly retune to get the car to run right.When they went back for retest,it passed but the numbers were worse.After doing some research,they determined that most vehicles properly tuned would pass the inspections with no emmisions control equipment,but that the emmisions would be lower on the average vehicle John Q. Public failed to maintain properly if it had the equipment.
I didn't intend to hijack,just felt the info might help someone.
Old 12-21-2012, 04:34 PM   #16
cdowns
cdowns's Avatar
i'd just go with two mufflers on each side the way the factory did with bigblock loluxoboats back in the days of horsepower // i'd think the mufflers are alot cheaper than the cats
Old 12-21-2012, 10:48 PM   #17
No issues after that. It sounded a bit throatier and ran maybe a tad better. The vehicles were my wife's rides. I have never personally driven anything that fell under the emissions requirements...either older or diesel. I just keep stuff running right because I take care of whatever I own and like them better that way. I try to avoid mandatory regulations as much as possible and take responsibility as a personal duty.
Old 08-09-2016, 08:58 AM   #18
farmsweet
Thanks for the information after some research I found out that 2 1/2" pipes all the way back would do better for my truck as the 3" pipes create a resonance within the exhaust. When the pipes are too big, it alters the resonance and in turn creates turbulence within the piping and messes with the back pressure. Its called Entropy. I still have 3" pipes on my 71 c10 but went with two long quiet mufflers from walker...and no cats..its still loud but sounds way better than before with the small 12" x 4" oval mufflers from Summit.
Old 08-09-2016, 11:45 AM   #19
AnotherWs6
AnotherWs6's Avatar
2 1/2" is not going to do any better volume wise and with a motor that large you are making good use of the larger 3" system. I have a 396 with 2 1/2" out the back and when I bought it it was AWFUL. Horrible tone, drone, rasp and effing loud. It got old REAL fast. I have 2 chamber flowmasters BTW. I did two things - h-pipe and resonators. The truck is still a BIT loud, but hey , it still has those loud ass flowmasters on there. But the sound quality improved dramatically. No more drone or rasp and I can actually have a conversation if I wanted to.
An h-pipe would be number one on the list to improve the TONE. Mufflers for sound and tone. Resonators for volume. I went with these.....
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
They make em in different lengths and sizes. You can see all of the positive reviews of people who were in the same boat as you and me. You'll see a bunch more similar reviews on Summit's website as well. I bought a Summit H-Pipe kit, two of the resonators and a bunch of Summit brand stainless steel band clamps (great quality, great price too!). Got it all hooked up in my driveway in a couple of hours with no welding. Just a sawzall, tape measure and ratchets. Did it a month or two ago.
You could do the same thing without fabbing a whole out-the-back setup and see what you think and then build off of that if it's still not good enough. It will be unless you're looking for suuuuper quiet.
Bullet mufflers, BTW, = Loud. They are usually jst straight through designs.
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 08-09-2016, 12:21 PM   #20
midniteblues
I don't know how I missed this reply.
I still have all oe exhaust on mine but I have a nice ss muffler
For it when I need it. I thought those cans on the y pipe were resonators but I'm not sure.
A friend called me last week and asked if I could weld up his cat. He cut it open and hollowed it out and muffler glued it back together
then when pulling his camper it blew out.
It is a 97 Yukon.
wow did it run and sound better after welding it up.
But now he said it's throwing o2 codes.
I haven't checked it out yet.
We are putting a rough country 2 1/2" lift on the kids 95 s10 blazer real soon an I figure once that is done we are gonna redo the exhaust again but hollowing the cat has me nervous
Because of the o2 sensors throwing codes.
His 92 did afterwards.
Anyway around this?
Here are my 2 magna flow cats for my car.
I figured since I paid for them I might as well save them in case I ever have issues with a inspections(not likely though).
They have the grid type thingy in them.
Old 08-09-2016, 01:14 PM   #21
davepl
davepl's Avatar
I'd consider a factory cat like the ones they use on the eRod LS3 engines - I have them on my '69 Camaro. They flow enough for 430 factory net hp, which is more than the 468 likely makes anyway (in factory net trim). My car also has a transverse muffler and between the two idles quiet like grandma's Biscayne. Fast and quiet!
Problem is I don't know how well your fuel trim is controlled. If it gets extra rich, do the converters overheat? I know very little about cats on carb'd engines, although my '75 Monte Carlo had both cats and a carb.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-09-2016, 07:32 PM   #22
farmsweet
Hey Thanks for the suggestion, an H-pipe would be better for the overall flow and tone. Sometimes I think too hard and things just go right over my head. Thanks again for your reply.
Old 08-09-2016, 10:14 PM   #23
jerry moss
Born Psycho
jerry moss's Avatar
out here in the peoples republic of california a bunch of you guys would be paying a big fine and/or jail time and your vehicle impounded thats why i drive my old stuff-no smog, no cats, no 02 sensors, no nothing. i work on late model crap every day and some of the stupid ass problems i see make me glad to own older trucks.
as to your loudness problem, run an x pipe, big block flows and full tailpipes and it will sound nice AND still perform like it should. don't waste you time putting cats on it, you will burn them up in no time unless you can moniter your fuel trims correctly.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 08-09-2016, 11:16 PM   #24
I still have all oe exhaust on....
I don't know why it took four years either!
Old 08-10-2016, 05:24 AM   #25
wbc409
Catalytic converters don't work right until they get hot. I was instructed when I was younger not to put cats on a vehicle that wasn't originally equipped because of a lack of heat shielding and the possibility of starting the carpet on fire. I imagine this would be more of a problem with a carbureted engine. Also if the engine runs rich it will ruin a cat fast.
wbc409 is offline   Reply With Quote
