Old 08-19-2016, 05:17 PM   #26
65Gregg
65Gregg's Avatar
Re: Speed Engineering LS Swap Headers Findings
Originally Posted by AustinBelair View Post
I've got them half installed in a 66 right now. I have a 4L80e so the PASS side does not fit and you have to trim the dust cover ears
Are you using the 1 3/4 or 1 7/8?
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 08-20-2016, 12:13 AM   #27
AustinBelair
Originally Posted by 65gregg View Post
are you using the 1 3/4 or 1 7/8?
1-7/8
My mother is a recent cancer survivor and this truck build is for her
AustinBelair is offline   Reply With Quote
Old 09-04-2016, 10:29 PM   #28
65Gregg
65Gregg's Avatar
My initial impression is that these are a great buy.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 09-05-2016, 07:31 AM   #29
Sik66
Yes.They doooo look pretty fricken nice!!.....be sure to post up some pics of what they look like in the chassis!....what mounts planning on using with them?....
Sik66 is offline   Reply With Quote
Old 09-05-2016, 07:34 AM   #30
Sik66
Ohh yeah....and which size set did you end up with?.
Old 09-05-2016, 09:26 PM   #31
65Gregg
65Gregg's Avatar
Originally Posted by sik66 View Post
ohh yeah....and which size set did you end up with?.
1 7/8", I'm using $30.00 eBay adjustable mounts from ICT billet.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 09-05-2016, 11:58 PM   #32
AustinBelair
Here is a pic
Old 09-12-2016, 11:11 PM   #33
bill1969camaro
Any pic. of the pass. side and how low below the frame do they hang?
bill1969camaro is offline   Reply With Quote
Old 09-12-2016, 11:15 PM   #34
bill1969camaro
I am doing a LS3 / 4L80 in a 1965 c10
Old 09-13-2016, 08:16 AM   #35
zach_carver
zach_carver's Avatar
These things look awesome.. My bank account would appreciate it if I would stay off this forum! LOL HAHA
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 09-19-2016, 10:42 AM   #36
67chevysupercharged
67chevysupercharged's Avatar
bill1969camaro,
It's kind of a bad camera angle, but in the fourth picture I posted you can kind of get an idea of how low they hang. It's been a while since I've looked at it, but I don't believe it hangs down much more than 1/2-3/4" below the frame, if that. Of course I have the 1 3/4 headers, the 1 7/8 may be a bit more.
-Zak
71 Longhorn 402, PS, PDB, AC, Tach, Posi
67 SWB 6.0 LSX swap, 4/6 ECE Drop (Work in Progress)
2002 Victory Red ECSB Silverado 5.3 (DD)
67chevysupercharged is offline   Reply With Quote
Old 09-19-2016, 03:37 PM   #37
t300
I bought the shorties - http://www.speed-engineering.com/fea...c10-truck.html .
So nobody runs into the same thing I did, stock plug wires will NOT fit, 3 of them on the driver side are pressed up against the headers. I was going to order the Accell 9000 series ceramic 135degree wires but some reports indicate they are not long enough and pull off the coils. So I ordered the Taylor TAY-76046 from Summit. Will see at end of week if they fit.
the notes for the long tubes indicate they are tight but vendor doesn't have the same warning for the shorties.
t300 is offline   Reply With Quote
Old 09-24-2016, 01:20 PM   #38
burlapen
burlapen's Avatar
I have them on my 63 with a t56 and ECE mounts. They fit great. Nice quality for the price.
63 Chevy C-10
My build thread
burlapen is offline   Reply With Quote
Old 09-26-2016, 07:15 PM   #39
65Gregg
65Gregg's Avatar
I instaled the 5.3 in my 65 over the weekend and put the 1 7/8 long tube headers on today, they fit fine. I'm not sure if the following will be of any help to anyone but I'll add it anyway. I used the original V8 stands in the rear position with ICT Billet mounts from eBay. The mounts are in the second position from the rear of the adapters. This allowed my trans mount to match my crossmember location because I didn't want to mess with the driveshaft length. I had the driveshaft shortened in 2001 when I changed to a 700R4. The only problem this has created that I've found so far is the rear coil on the passenger side hits the firewall, not the end of the world. The drivers side has a ton of room but the primary for cylinder #4 is about 1/4" from the frame. The ground clearance is higher than when I had long tubes on the ZZ4 I pulled to the 5.3.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 01-12-2017, 11:28 AM   #40
PowerdbyChevy79
PowerdbyChevy79's Avatar
got any pics brother
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 01-12-2017, 10:40 PM   #41
65Gregg
65Gregg's Avatar
Anything specific you want a picture of?
65Gregg
Blue long bed
White TBSS
61 Impala
Old 01-13-2017, 11:33 AM   #42
PowerdbyChevy79
of how the headers fit...
1966 C10 "Mary"
Old 01-13-2017, 06:05 PM   #43
aggie91
I'm just glad to be here!
aggie91's Avatar
And the ground clearance from the side...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-14-2017, 12:38 AM   #44
65Gregg
65Gregg's Avatar
I'll have to take a side view next week when I put my engine back in, the cam retention plate was creating oil pressure issues. I hope to pick it up from the machine shop Monday.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 01-14-2017, 12:41 AM   #45
65Gregg
65Gregg's Avatar
QUOTE=PowerdbyChevy79;7824749]of how the headers fit...[/QUOTE]
65Gregg
Blue long bed
White TBSS
61 Impala
Old 01-14-2017, 12:45 AM   #46
65Gregg
65Gregg's Avatar
This kind of gives an idea of how they hand down, the trans X member is in the foreground.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 01-16-2017, 01:33 PM   #47
PowerdbyChevy79
wow.. they tuck in nicely.. great work brother...
1966 C10 "Mary"
Old 01-18-2017, 10:06 PM   #48
Sturvin
Anyone have pics of plug wires that clear the primaries? And which ones they used?
Sturvin is offline   Reply With Quote
Old 01-19-2017, 07:49 PM   #49
coreyjhen
Those collectors look like they're pointed directly at the trans crossmember. Did you have any problems routing the exhaust?
coreyjhen is offline   Reply With Quote
Old 01-19-2017, 10:15 PM   #50
65Gregg
65Gregg's Avatar
No, there is about 8-10" on the driver side and a little less on the passenger side, the muffler shop put a couple on small bends in and was able to tie into my existing pipes. I'll post a picture in the next few days.
65Gregg
Blue long bed
White TBSS
61 Impala
