Old 08-31-2016, 01:28 PM   #1
cagodinez
cagodinez's Avatar
no spark how to trouble shoot coils?
2008 5.3 engine will not start but, it does turn over and I have 80psi at the fuel rail when cranking, I checked for spark and nothing, how do I trouble shoot the coils? Should I pull the fuel rail along with the injectors to see if they are all spraying? Any help greatly appreciated.
cagodinez is offline   Reply With Quote
Old 08-31-2016, 02:46 PM   #2
66ChevyMax
66ChevyMax's Avatar
Re: no spark how to trouble shoot coils?
Did you check the ignition fuse?
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 08-31-2016, 06:25 PM   #3
cagodinez
cagodinez's Avatar
I checked all the fuses, they are good.
Old 08-31-2016, 08:24 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Take a look at the harness that branches off of each coil on to the main leg. Those wires can occasionally get pinched, pulled, or broken (usually when the valve covers needed to be accessed, the coils all get moved, and the harness gets damaged).
Do you not get spark on ANY of the leads, or just on a few? If you don't get spark on anything, its usually not the coils to blame.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-31-2016, 08:35 PM   #5
jjzepplin
jjzepplin's Avatar
I used my old school timing light on my 2002 Toyota individual coils and it lights just a bunch of times instead of just once like the old gen 1's. I was able to locate the bad coil as it did not make any lights at all. I just clamped the plug wire clamp to the small wires going to the coils.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-31-2016, 11:28 PM   #6
dayj1
I know it's not specifically about the coils, but make sure that your engine sensors, coils, injectors, etc. are getting power when the ignition is in the "start" position. It's a common mistake to wire it up with a source that is only hot when the ignition is in the "on" position and not "start". Good luck!
dayj1 is offline   Reply With Quote
Old 08-31-2016, 11:50 PM   #7
cagodinez
cagodinez's Avatar
ok so I checked all 8 coils going to the pink wire on each one of the connectors and they are all getting 12volts but, I checked the black wire on all 8 for chassis ground and nothing. I think I missed one of the grounds on the harness but I can't find it.
Old 09-01-2016, 09:19 AM   #8
66ChevyMax
66ChevyMax's Avatar
My harness had 3 ground wires that are tied to the block
Craig
Old 09-01-2016, 09:28 AM   #9
ls1nova71
ls1nova71's Avatar
The ground for the coils is usually behind the power steering pump, on the left lower side of the block.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-03-2016, 02:19 PM   #10
cagodinez
cagodinez's Avatar
well well well what do we have here.....
Old 09-04-2016, 11:13 AM   #11
ls1nova71
ls1nova71's Avatar
I'd say a ground that wasn't hooked up.... Good thing it wasn't touching anything, if it were, it may have run sometimes and other times not, which would have been harder to diagnose over the internet!
Old 09-04-2016, 06:37 PM   #12
cagodinez
cagodinez's Avatar
She fired right up but, the throttle is not responding, I think it's because I'm running a 2008 Impala pedal. Also I'm getting a misfire, I'm going to check the injectors.
Old 09-07-2016, 01:19 AM   #13
cagodinez
cagodinez's Avatar
Swaped D and F pins on the pedal connector and that did it, I'm getting instant throttle response. I erased the p2138 code hope it don't come back.
Old 09-07-2016, 08:23 AM   #14
66ChevyMax
66ChevyMax's Avatar
Congratulations!
Craig
Old 09-07-2016, 02:16 PM   #15
cagodinez
cagodinez's Avatar
Thank you Craig.
Old 09-08-2016, 10:56 PM   #16
ls1nova71
ls1nova71's Avatar
^^^^^ wtf?????
Old 09-08-2016, 11:18 PM   #17
solidaxel
solidaxel's Avatar
Originally Posted by ls1nova71 View Post
^^^^^ wtf?????
YES !!
First post too!
I am sure there is a very good explanation for this................. maybe not!!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-10-2016, 04:55 PM   #18
cableguy0
Originally Posted by solidaxel View Post
YES !!
First post too!
Its spam and has been removed. That person or robot will be removed from the site shortly.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-10-2016, 06:58 PM   #19
cagodinez
cagodinez's Avatar
Am I missing something???
Old 09-10-2016, 09:37 PM   #20
ls1nova71
ls1nova71's Avatar
Apparently you didn't see it, but there was a post that was like a hunderd lines or so, it was loooooong, something about football players or something, didnt read it all but it didn't make any sense to me.
Old 10-23-2016, 08:00 PM   #21
cagodinez
cagodinez's Avatar
Just wanted to thank everyone for your help, I got more input here than any other site, well maybe LS1TECH was helpful also, Ls1Nova would always respond to my novice questions. Took her out for the 1st time and it seems like I might have a vacuum leak, it revs really high when I'm at a stop.
