Old 09-19-2016, 01:39 AM   #1
Cjcolbyjack
5.3 stromberg look alike big block
This is my 51 with a stock 5.3 that came out of a 01 Silverado. I flipped the stock intake around and ran it thru the cab to the old heater vent on the passenger side. The top is just pvc, fiberglass and muffler tips. The Chevy emblem on the front is the original horn button that was in the truck when i brought it home. Built brackets for the big block valve covers to hide the ugly coil packs. ceramic coated stock manifold. Name:  20160606_182808.jpg
51 motor buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=718113.
54 3600 Lincoln aviator chassis swap
http://67-72chevytrucks.com/vboard/s...d.php?t=717927
Cjcolbyjack is offline   Reply With Quote
Old 09-19-2016, 01:47 AM   #2
Cjcolbyjack
Re: 5.3 stromberg look alike big block
This is now my air intakeName:  20160606_182505.jpg
Size:  48.2 KBnormally a worthless vent. I'll have to post pics of how I ran it though the cab tomorrow.
Old 09-19-2016, 10:01 AM   #3
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
That's awesome, nice work!
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 09-19-2016, 11:14 AM   #4
solidaxel
solidaxel's Avatar
Good plan, I like that idea!
Need more information on the Valve covers also
................ I like Black trucks !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-19-2016, 04:01 PM   #5
Cjcolbyjack
Thank you so much for the compliments. The Valve cover or the brackets for them. What's your question solid? The brackets I made out of plastic bins. I pulled them out of someone's trash, they were pretty thick. I did that 10 years ago. Now you can buy kits to do the same thing. The valve covers them selves I believe are eldelbrock. Again it was 10 years ago when I bought them.
Old 09-19-2016, 05:54 PM   #6
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work and awesome truck!
Ryan
1969 Chevy milk truck
Old 09-19-2016, 11:26 PM   #7
oldman3
oldman3's Avatar
Sweet looking ride...Jim
oldman3 is offline   Reply With Quote
Old 09-20-2016, 12:48 AM   #8
solidaxel
solidaxel's Avatar
So the V covers are BBC using a adapter from center bolt to perimeter bolt
Which coils did you use and what bracket?
LS 3 4L70E
Old 09-20-2016, 06:53 PM   #9
Cjcolbyjack
I kept the stock coil packs that you see. They fit easily under the bbc v covers. I only had to make a 1-1/4 hole to extend the oil fill up. I kept everything stock because I wanted to keep it reliable. Considering the AD is 2000 lbs lighter than the 01 Silverado it came out of. It's very quick.
Old 09-20-2016, 08:23 PM   #10
kashola
Nice work. I like to see the creativity people put into disguising these motors. Truck is gorgeous.
kashola is offline   Reply With Quote
Old 09-20-2016, 10:43 PM   #11
solidaxel
solidaxel's Avatar
Thanks I guess I missed the rest of the pics
I knew there was a use for those louvers
............... Where did you place your evaporator?
LS 3 4L70E
Old 09-21-2016, 10:55 PM   #12
Cjcolbyjack
I've seen so many creative ideas on this forum! the least I can do is to share my creations. Lol. Thanks for the compliments!
Old 09-21-2016, 11:17 PM   #13
Cjcolbyjack
[QUOTE=solidaxel;7719586]Thanks I guess I missed the rest of the pics
............... Where did you place your evaporator?[/QUOTE
Are you talking about the lovers on the side? Because everything on top of the air intake is just for looks. Here's a pic inside of the cab. I have the evaporator, well full vintage air I have not installed yet. I'm hoping I can squeeze it in somehow.Name:  IMG_0443.jpg
Old 09-22-2016, 01:15 AM   #14
izzy_Britton
izzy_Britton's Avatar
What is the story behind this seemingly HUGE idler/tensioner pulley? I like it!
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 09-22-2016, 11:33 AM   #15
solidaxel
solidaxel's Avatar
Yes the louvers on the A piller, I cut mine out as I did not see a use for them with A/C
You may have enough room with your evap and your air box but it will be tight !!
LS 3 4L70E
Old 09-22-2016, 09:24 PM   #16
Cjcolbyjack
Originally I had the alternator mounted on the bottom right of the motor, which I liked so much more. The alternator was grounding out when it got water near it. The pulley was just what I had to make it work.
Old 11-16-2016, 07:40 PM   #17
jkeating1
jkeating1's Avatar
OK--So I've been following your '54 Aviator build in amazement, then I see this thread where you've already done another setup I've been pondering with the reversed intake through the firewall. I like the idea of the outside air coming through the louvers--I was trying to come up with a design that used the cowl vent, and shedding water was an issue.
One thing I was concerned about was the short distance to the firewall--I thought chafing/breaking/squeaking of the intake pipe might be a problem with the engine torque movement and general movement of the body.
After writing this, it occurs to me that this is a pretty insignificant hurdle when I look at your '54 pics!
What chassis is the '51 on?
John
jkeating1 is offline   Reply With Quote
Old 11-20-2016, 02:20 AM   #18
Cjcolbyjack
John
I'm sorry I thought I already responded to this. To answer your questions.
Where I went through the fwall I simply used a rubber section along with using the bolts for the mas. No squeaks at all. In fact the only noise I hear is when I get into it and it's sucking air, I can hear it a little. Keep in mind this is not idea for hp. You'll want better air flow. I haven't had any issues, but I left it stock.
The 51 has a 77 firebird front clip along with the firebird rearend. Thanks so much for the compliments. If you have any more questions please ask.
5.3 swap, ceramic, fake, lsx, stromberg
