Old 02-04-2017, 04:04 PM   #1
rvrfoot
Bed to cab gap
My truck was a long bed.I cut it to a short bed.I need pictures of the bed to cab gap.My bed look like its too close.
rvrfoot is offline   Reply With Quote
Old 02-04-2017, 04:37 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Bed to cab gap
Before and after paint...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-07-2017, 01:50 AM   #3
Vinceg
Vinceg's Avatar
Re: Bed to cab gap
Anyone measure the gap? I cut my bed down to a short bed also. The gap from the back of the cab to the front box panel measures 11/8 inch on one side and 1 inch on the other. I need to spend some time getting it all straight but im curios about an actual measurement myself.
Vinceg is offline   Reply With Quote
Old 02-07-2017, 09:34 AM   #4
vin63
vin63's Avatar
Re: Bed to cab gap
Mine is right at 1 inch.
Old 02-07-2017, 10:25 AM   #5
LT1 Burb
LT1 Burb's Avatar
Re: Bed to cab gap
1" is about right.
LT1 Burb is offline   Reply With Quote
Old 02-07-2017, 10:29 AM   #6
LT1 Burb
LT1 Burb's Avatar
Re: Bed to cab gap
Run a tape from the front right to rear left and then opposite, this will tell you if you are square, there is a surprising amount of movement.
Old 02-07-2017, 10:30 AM   #7
Vinceg
Vinceg's Avatar
Re: Bed to cab gap
Thanks for the reply guys. My truck goes back for final paint soon. Once its done i will be able to line it up better and bolt it down.
Old 02-07-2017, 10:37 AM   #8
Vinceg
Vinceg's Avatar
Re: Bed to cab gap
I know what you meen. Ive been very surprised at the amount of movement when it comes to reassembly. I had to loosen my cab mount bolts and adjust the cab forward. I was having trouble with my inner fenders. I was blown away. You really need to have a close look at the whole thing when you put it back together not just the part your working on. Especially when you've stripped it to the fram and done the amount of work I've had to do. Thanks again.
Old 02-07-2017, 12:51 PM   #9
vin63
vin63's Avatar
Re: Bed to cab gap
Yeah, my painter initially wanted to remove the cab to paint it...I told him "no way" since I had aligned all of the sheetmetal before dropping the truck off to him. I didn't want to re-live that whole process with all of the sheetmetal painted.
