Old 02-09-2017, 12:10 AM   #26
Jason7121
Jason7121's Avatar
Re: 1969 Chevy short stepside
The fuel tank fit well. I had to put 1" spacers etween mounting flange and frame rail so bottom rail of bed wouldn't smash my fuel lines.
Jason7121 is offline   Reply With Quote
Old 02-09-2017, 11:09 AM   #27
doc74021
Okay thanks for the tip.
doc74021 is offline   Reply With Quote
Old 02-10-2017, 10:27 PM   #28
doc74021
Tonight I was able to get the cab off the frame and on a dolly.
Old 02-10-2017, 10:30 PM   #29
doc74021
I did not have the frame sandblasted because it looked really good just stripping the old paint off and then I painted it with a high temp chassis paint. I will work on the whole frame this weekend.
Old 02-10-2017, 10:49 PM   #30
doc74021
I have looked at thousands of paint jobs and colors trying to decide what I want to do with this truck and my plan is to faux patina it similar to the one in the picture.
Old 02-11-2017, 01:14 AM   #31
Jason7121
Jason7121's Avatar
Wow that will be killer!
Old 02-11-2017, 10:00 AM   #32
doc74021
Another member on here did the same with his truck and it turned out really good. The only thing I'm going to do different is use a red oxide primer rather than black so it looks like rust spots.
Old 02-11-2017, 07:48 PM   #33
doc74021
Fed ex showed up today with my gas tank from cpp and my trailing arm bushings and some door hinge pins and bushings. This morning I finished cleaning the frame all up and got it painted. I also got the trailing arms primered and painted. I also got some spacers to put the front tires on to be able to move it.
Old 02-11-2017, 07:50 PM   #34
doc74021
More pics
Old 02-12-2017, 10:12 PM   #35
doc74021
I was able to get an hour or so in tonight. I worked on putting my cab back together. Got the upper kick panels set in place and got the inner cowl piece set in place with a few spot welds. It was good to see it look like a cab again.
Old 02-12-2017, 10:14 PM   #36
doc74021
Another pic
Old 02-13-2017, 08:06 PM   #37
doc74021
Did some more spot welding and set the cowl on just to remind me what it looks like lol. I had intended on using disc brakes on the rear but just couldn't justify the cost since I got all new drum brake parts for less than 200 dollars.
Old 02-19-2017, 11:17 PM   #38
doc74021
Haven't updated in a bit but I got the rear axles changed out and got the rear end back under the chassis and finished the drop kit on the rear. I got the frame rolling so that's a plus.
Old 02-22-2017, 10:38 AM   #39
doc74021
Updating pics.
Old 02-22-2017, 10:39 AM   #40
doc74021
More pics.
Old 02-22-2017, 10:42 AM   #41
doc74021
Originally Posted by doc74021 View Post
More pics.
Pics.
Old 02-22-2017, 10:45 AM   #42
doc74021
My dash only had one rust spot on it. Unfortunately, it was a pretty good one. I pulled the dash from the donor cab and cut out the piece I needed.
Old 02-22-2017, 11:03 AM   #43
faribran
Nice work. Keep it up!!!
faribran is offline   Reply With Quote
Old 02-22-2017, 02:32 PM   #44
doc74021
Thanks!!
Old 02-22-2017, 08:25 PM   #45
Rod Run
Rod Run's Avatar
I loved how nice my CPP gas tank fit in my frame
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 02-23-2017, 10:05 PM   #46
doc74021
I was pretty impressed with it myself.
Old 03-02-2017, 09:22 PM   #47
doc74021
I used the dash out of the donor cab to cut a piece and fix mine. I welded it all in and grinded it all down and slapped some filler on it. After sanding I put some primer on it.
Old 03-02-2017, 09:25 PM   #48
doc74021
I cut out some sheet metal for my blank off plates and started spot welding them in.
Old 03-02-2017, 09:29 PM   #49
doc74021
I finally got my motor. I had plans to rebuild the 350 that came out of the truck but after pricing everything I ordered a 350 from radley Chevrolet.
Old 03-02-2017, 09:31 PM   #50
doc74021
Not sure why some of my pics come out sideways and some are normal because I take pics the same way every time.
