Old 02-11-2017, 01:14 AM   #1
Jason7121
Jason7121's Avatar
Re: 1969 Chevy short stepside
Wow that will be killer!
Jason7121 is offline   Reply With Quote
Old 02-11-2017, 10:00 AM   #2
doc74021
Another member on here did the same with his truck and it turned out really good. The only thing I'm going to do different is use a red oxide primer rather than black so it looks like rust spots.
doc74021 is offline   Reply With Quote
Old 02-11-2017, 07:48 PM   #3
doc74021
Fed ex showed up today with my gas tank from cpp and my trailing arm bushings and some door hinge pins and bushings. This morning I finished cleaning the frame all up and got it painted. I also got the trailing arms primered and painted. I also got some spacers to put the front tires on to be able to move it.
Old 02-11-2017, 07:50 PM   #4
doc74021
More pics
Old 02-12-2017, 10:12 PM   #5
doc74021
I was able to get an hour or so in tonight. I worked on putting my cab back together. Got the upper kick panels set in place and got the inner cowl piece set in place with a few spot welds. It was good to see it look like a cab again.
Old 02-12-2017, 10:14 PM   #6
doc74021
Another pic
Old 02-13-2017, 08:06 PM   #7
doc74021
Did some more spot welding and set the cowl on just to remind me what it looks like lol. I had intended on using disc brakes on the rear but just couldn't justify the cost since I got all new drum brake parts for less than 200 dollars.
