Old 02-02-2017, 10:47 AM   #26
57taskforce
All about them K’s
57taskforce's Avatar
Re: Eaton HO72 rear axle
Originally Posted by RPOZ11 View Post
Thanx
I'm still working on the chunk parts id'ing.
I'll be posting up the housing after I have it cleaned.
What's next is to reassemble the hubs with the new TimKen bearings.
Re-install it all to double check everything, then move into the brake system.
I'm working on brake systems.
Give me a few weeks here.
My work hopefully will shed some results
Nice progress!
Tyler
Old 02-11-2017, 04:28 PM   #27
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Axle housing, backing plates, inspection cover stripped.
Now at powder coating shop to be covered in black.
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 02-12-2017, 05:57 PM   #28
Tdrcreyn4
Tdrcreyn4's Avatar
subbed
1968 C10 292/3 spd - sold
1969 K10 350/3 spd/205 - sold
1971 K5 350/4 spd/ 205 - sold
1970 K20 350/350/205 - sold
1969 K20 396/400/205 - work in process
Tdrcreyn4 is offline   Reply With Quote
Old 02-18-2017, 05:33 PM   #29
RPOZ11
RPOZ11's Avatar
Ready to reassemble ...
HO72 build :
2017 SS
Old 02-18-2017, 06:49 PM   #30
B. W.
B. W.'s Avatar
You may have already found this info. The tag denotes what type of differential, can't remember if it's gear ratio or locker/open/ limited slip. GM used different shaped tags with no data on them to differentiate differentials (yeah, that was a play on words)
B. W. is offline   Reply With Quote
Old 02-18-2017, 07:12 PM   #31
RPOZ11
RPOZ11's Avatar
I do still have the tag from it.
No info present on it.
As suggested, the stamped code on the drop out defined its build.
We are currently in the process of sizing up all the bearings for fit.
Paint up the hubs then install the bearing races for it.
Waiting for the disc brake brackets to arrive so we can try that on this.
Still need to buy the calipers, rotors, brake lines, and rebuild the Ring & Pinion.
Going to try the 14-Bolt Locker & 14-Bolt axles.
Its all new for me.
My first attempt at doing a rear axle
HO72 build :
2017 SS
Old 02-25-2017, 06:28 PM   #32
RPOZ11
RPOZ11's Avatar
DIY 4X4 14-Bolt Disc Brake brackets
They fit! 😎
HO72 build :
2017 SS
Old 02-25-2017, 06:59 PM   #33
BlueBullet
BlueBullet's Avatar
Looking good thanks for providing all the information
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 02-25-2017, 07:42 PM   #34
RPOZ11
RPOZ11's Avatar
My pleasure!
I'm learning as I do it all.
Eaton Detroit Locker 225S-10 DL 14- bolt
Need a few weeks to disassemble the ring & pinion assembly, powder coat the carrier, then reassemble with the Detroit Locker.
I will then order new axles made to fit this Locker.
(poor lighting made the image appear rusty)
HO72 build :
2017 SS
Old 02-26-2017, 12:18 AM   #35
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
subscribed
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 02-27-2017, 09:06 PM   #36
RPOZ11
RPOZ11's Avatar
Carrier apart :
GM part # :
3934635
GM Parts Catalog shows :
3934634
68-72 Ser. 20-30 (exc. 11,000 lb. axle)
Cataolg does NOT state W or W/O side load bolt
HO72 build :
2017 SS
Old 02-27-2017, 09:09 PM   #37
RPOZ11
RPOZ11's Avatar
Pinion Support
GM part # :
3843067
HO72 build :
2017 SS
Old 02-27-2017, 09:10 PM   #38
RPOZ11
RPOZ11's Avatar
YOKE
NO GM part # present
HO72 build :
2017 SS
Old 03-05-2017, 08:29 PM   #39
RPOZ11
RPOZ11's Avatar
Rotors :
Dura International # BR5523
Studs :
Dorman # 610-194
HO72 build :
2017 SS
Old 03-05-2017, 08:38 PM   #40
RPOZ11
RPOZ11's Avatar
And something new I learned today :
Escalade Hub Seals :
National # 710568
These seals resolve the leaking hub seal after they have grooved the housing
HO72 build :
2017 SS
Old 03-10-2017, 02:20 PM   #41
RPOZ11
RPOZ11's Avatar
Rear Caliper on for test fit:
HO72 build :
2017 SS
Old 03-10-2017, 05:08 PM   #42
RPOZ11
RPOZ11's Avatar
Carrier, support, & yoke stripped and ready for black powder coat :
HO72 build :
2017 SS
Old 03-19-2017, 02:17 AM   #43
RPOZ11
RPOZ11's Avatar
Just an update.
Working on rear calipers.
Possibly going to look into reproducing parking brake brackets and springs.
Aftermarket new calipers look ok.
The core GM calipers need some attention.
Powder Coating was delayed; so I'm a week behind now.
Once I can get all this resolved I can then order the axles.
Until then, same old slow process.
Never imagined the cost of doing these.
And I have 2 more to do.
More updates to come...
HO72 build :
2017 SS
Old 03-19-2017, 04:55 AM   #44
Shaky
Six in a row makes it go...
Shaky's Avatar
Yeah - the price on that bearing kit is eye-opening. I like my HO52, but if it ends up needing too much I might have to consider a 14-bolt. Nice work - following with interest...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 03-19-2017, 05:02 PM   #45
RPOZ11
RPOZ11's Avatar
Well I'm into it deep now.
Goal is to complete it.
Powder Coating :
HO72 build :
2017 SS
Old 03-19-2017, 05:06 PM   #46
RPOZ11
RPOZ11's Avatar
Side Load Bolt :
HO72 build :
2017 SS
Old 03-19-2017, 11:27 PM   #47
RPOZ11
RPOZ11's Avatar
So here we have my 14 Bolt axles out sitting side by side as an example of the length comparison/differences.
17-30 spine difference.
Length difference using a straight edge of a bar to show how close they are & how I need to order shorter axles so that they dont hit or become a clearance issue.
Once I get the ring & pinion back from being assembled, I will then discuss further what is necessary with the axles.
Bear with me.
This will take a few weeks to finalize this all.
HO72 build :
2017 SS
Old 03-20-2017, 11:25 AM   #48
Theboatandcarman
i am looking forward to an axle comparison. i want to put a 14 bolt locker in my ho72
keep on building. http://67-72chevytrucks.com/vboard/s...d.php?t=680094
2017 GMC Canyon diesel
1968 Chevrolet C20
1970 Mercedes 280S
(WTB 1968 4wd barn door suburban)
Theboatandcarman is offline   Reply With Quote
Old 03-20-2017, 04:31 PM   #49
Shaky
Shaky's Avatar
I hear you. I've spent a lot of money with less to show for it. You're gonna end up with a nice piece (or three).
Old 03-25-2017, 06:48 PM   #50
RPOZ11
RPOZ11's Avatar
This one isn't mine but a similar rear disc swap.
With the vented rotors, the rotor outside diameter was a small bit too much from the manufacturer.
What was happening was that the rotor was slightly hitting the caliper pin.
His remedy was to take off ONLY enough material to keep it from hitting.
In the image below, you will see that he took off more material than was needed but leaving enough surface area to show full contact of the brake pads.
Just an FYI; but I thought it was worth sharing.
Maybe not all rotors have this problem.
HO72 build :
2017 SS
