Old 08-07-2016, 07:49 PM   #1
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
HO72 rear axle
Just picked this up
HO72 Detroit Locker rear axle
Drum to Drum
Here is the code and tag from it
Can anyone decipher the stamped code?
R JJG0761
Tag has no info on it
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 08-07-2016, 07:50 PM   #2
RPOZ11
RPOZ11's Avatar
Re: Eaton HO72 rear axle
Tag
HO72 build :
2017 SS
Old 08-08-2016, 01:08 AM   #3
RPOZ11
RPOZ11's Avatar
I'm also curious to the REAL name for these.
I'm seeing Rockwell Meritor
I was under the assumption that these were Eaton related.
I am seeing the R preceding the code for the gear ID.
I need to also look at the casted in part # also present.
So what is considered the official name of these?
HO52 & HO72
HO72 build :
2017 SS
Old 08-08-2016, 01:33 AM   #4
RPOZ11
RPOZ11's Avatar
Just found this:
Detriot Gear & Axle - G
G = Plant
G = Chevrolet G&A Positraction Carrier
HO72 build :
2017 SS
Old 08-08-2016, 07:39 PM   #5
bw46
bw46's Avatar
You lucky dog! I have one of those but without the locker. I wish i could find a factory locker.
The Eaton rear ends are very sturdy. Only downside is that it's harder to find parts. But they're so stout they shouldn't break if reasonably taken care of.
bw46 is offline   Reply With Quote
Old 08-09-2016, 02:07 AM   #6
swamp rat
swamp rat's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=590959
2nd page post 26, lists a chart for 72., your code:
Prefix: RJJ, Model: KE20, ratio: 4:10N,
*N designation is No Spin.
There is still a good possibility this is an HO52 not a 72, some Ho52's utilized the same ring gear and load bolt, the brakes were however larger.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-09-2016, 11:02 AM   #7
RPOZ11
RPOZ11's Avatar
What an amazing amount of research you've provide.
Your link is pricless
TY
Ya, I'll assume its an HO52.
It does have the load bolt
Smaller brakes than what I have on the LongHorn
HO72 build :
2017 SS
Old 12-26-2016, 11:03 PM   #8
RPOZ11
RPOZ11's Avatar
Where do I find suppliers who actually stock the parts for these?
I found this link :
http://shop.cruiserparts.net/index.p...ducts_id=11557
I just helped a friend with going thru the LH brake system on one of these.
He needs a new lock retainer; as the previous owner(s) damaged it.
Im not sure where to locate this stuff.
And I have yet to begin on my HO72 in my Longhorn.
Thoughts..
Thx
HO72 build :
2017 SS
Old 12-27-2016, 09:31 AM   #9
Shaky
Six in a row makes it go...
Shaky's Avatar
Very limited parts availability for these. What kind of parts are you looking for? Seals and bearings are around. Gears - not so much.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 12-27-2016, 09:52 AM   #10
RPOZ11
RPOZ11's Avatar
Original Lock retainers
Original brake adjusters (His are locked up)
Using a calcium lime soluition, this was submerged for 24 hours and it freed up the adjuster.
Original drain plug (His was damaged)
HO72 build :
2017 SS
Old 12-27-2016, 12:07 PM   #11
RPOZ11
RPOZ11's Avatar
So, when I'm actually looking up parts for these,
I there a parent name it all falls under?
When I research the internet,
I typically type in HO52 or HO72.
Could there be a more main title all the parts fall under?
These go back years, and I'm unsure the production years for the HO72 release
HO72 build :
2017 SS
Old 12-29-2016, 07:30 PM   #12
suprachrgd82
Farmtruck desciple
suprachrgd82's Avatar
This thread is a great read. Long, but full of info about these axles.
http://www.pirate4x4.com/forum/chevy...aton-h072.html
suprachrgd82 is offline   Reply With Quote
Old 01-01-2017, 11:00 AM   #13
RPOZ11
RPOZ11's Avatar
Cool Re: Eaton HO72 rear axle
Thanx !
HO72 build :
2017 SS
Old 01-02-2017, 01:21 AM   #14
RPOZ11
RPOZ11's Avatar
Ive looked up more about these.
(Work so much that it takes me a while to make some progress on this)
Yukon offers a Master Overhaul kit using a Tapered Pinion Bearing for the Load Bolt design :
https://www.yukongear.com/productdet...px?ProdID=4271
If you have the HO52, then I suppose you can sell that thrust bolt to us here on the site.
Randy's offers up the same kit :
https://www.ringpinion.com/b2c/Produ...px?ProdID=4271
So, with some further research, it appears that Timken is the bearing brand provided in this.
Looking up Timken, they may be a US company, but they do manufacturer items they sell via offshore locations.
This part might be made here in the USA, China, India, or who knows whatever new factory that they contract with.
Most readings I find suggest opening up the packaging and determine where it was made.
You may get 2 bearings where one is made here and one somewhere else.
No consistency.
The small parts I am seeking I am still researching.
got a lead on these small parts...
will advise asap
HO72 build :
2017 SS
Old 01-02-2017, 12:40 PM   #15
TCCGRIZ
Has anyone done the disc brake conversion on there Eaton as described in one of the links . If so any part numbers ?? They used stuff from a 14bff I believe . I have 2 k20's would be a nice upgrade .
TCCGRIZ is offline   Reply With Quote
Old 01-02-2017, 12:43 PM   #16
RPOZ11
RPOZ11's Avatar
As I've come to understand it,
I believe that the FF 14-Bolt aftermarket brackets bolt right up to these.
I'd consider doing it but I really don't want to disturb my factory brake lines.
My truck, I plan on keeping it all original; mostly.
However, I do have this extra HO52.
I am looking into swapping in the FF 14-bolt side gears and installing the Detroit unit.
If that all works as suggested, I just may move forward into installing that disc brake setup.
In do time.
Gotta buy up these parts first.
HO72 build :
2017 SS
Old 01-02-2017, 08:59 PM   #17
RPOZ11
RPOZ11's Avatar
Started tearing into this axle today.
GM ring gear part # : 3934647
Ratio : 10:41
Date : 2/1972
Pics
HO72 build :
2017 SS
Old 01-08-2017, 09:52 PM   #18
RPOZ11
RPOZ11's Avatar
HO52 Drum, Hub assembly apart
The 12 X 2-1/2 drum GM # is 3998512
The Hub GM part # is 3988535
The bearings found installed are :
KOYO 388-A
Bower 368 or 388-S (can't determine yet)
Seal part # is 2081
Anyone have any input on the outer beating part numbers?
HO72 build :
2017 SS
Old 01-14-2017, 12:15 AM   #19
RPOZ11
RPOZ11's Avatar
Figured out the lock retainer :
Dorman 618-049
Brand new
HO72 build :
2017 SS
Old 01-14-2017, 12:16 AM   #20
RPOZ11
RPOZ11's Avatar
Made up some tools to remove & install the bearings and races.
HO72 build :
2017 SS
Old 01-14-2017, 06:33 AM   #21
72freak
Rottenwood Garage Member
72freak's Avatar
A lot of these parts are out of production, limited and hard to find. I finally pulled mine a few years ago and switched to an axle I could actually get arts for. It was a sad day but one that had to happen. Great find though!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 01-16-2017, 12:35 AM   #22
RPOZ11
RPOZ11's Avatar
More part #'s :
Some may be available, Some may not be.
Some of this crosses over into 1973 and up.
It appears that GM continued using the same axle spindle dimensions.
The drums look to be obsolete now.
Axle Spindle nut (4):
Dorman 615-130
2"-16 thread
Axle Spindle washer (2) :
Dorman 618-048
2" X 2-5/8"
(on occasion, these may need to be clearanced on the inside diameter where it passes over the spindle. They are tight or do not pass over the threads. I had to de-burr the 2 Dorman washers that I used)
Axle spindle LOCK retainer (2) :
Dorman 618-049
2" X 2-9/16"
Axle Shaft Flange Gasket
(O-Ring or Seal)
Fel-Pro 55350
Hub bearings
Timken 388A (large bearing)
Timken 382 (large bearing race)
Timken 368S (small bearing)
Timken 362 (small bearing race)
Rear Hub Seal :
National PM2081
National 710568 (Escalade)
The Escalade seal above resolves the 2081 from leaking due to wear grooves that occur on the landing area for the housing.
Differential cover gasket :
Clevite P-39130
Mahle P-39130
Victor (Reinz) P-39130
JEGS 695-P39130
Fel-Pro RDS 5088
Drop Out Carrier gasket :
Fel-Pro RDS 5090
Pinion Seal :
Yukon YMS411330N
Part # : 807-YMS411330N (JEGS)
Pinion Shims :
Yukon SK20100
Part # : 807-SK20100 (JEGS)
Yukon Differential Bearing Kit :
Yukon BKGMHO72B
Part # : 807-BKGMHO72B (JEGS)
B - denotes "Load-Bolt"
12" Brake shoes:
Wagner Perfect Stop # PSS248DR
HO72 build :
2017 SS
Old 01-29-2017, 12:22 AM   #23
RPOZ11
RPOZ11's Avatar
Housing stripped down bare
HO72 build :
2017 SS
Old 02-01-2017, 09:29 PM   #24
Theboatandcarman
good work and nice references! ive been searching for a 4.11 no spin for 4 months now....
keep on building. http://67-72chevytrucks.com/vboard/s...d.php?t=680094
2017 GMC Canyon diesel
1968 Chevrolet C20
1970 Mercedes 280S
(WTB 1968 4wd barn door suburban)
Theboatandcarman is offline   Reply With Quote
Old 02-02-2017, 02:04 AM   #25
RPOZ11
RPOZ11's Avatar
Thanx
I'm still working on the chunk parts id'ing.
I'll be posting up the housing after I have it cleaned.
What's next is to reassemble the hubs with the new TimKen bearings.
Re-install it all to double check everything, then move into the brake system.
I'm working on brake systems.
Give me a few weeks here.
My work hopefully will shed some results
HO72 build :
2017 SS
