Old 03-13-2017, 01:03 PM   #1
71ChevyCheyenne
1971 C10 5spd swap
Hi everybody I'm new to this site and looking for help,
I have a 1971 Chevy C10 that currently has the sm465 transmission. I'm looking for a 4 speed with overdrive to swap in. I've been looking around and it seems like a NV3500 could work but, I would have to switch to a hydraulic clutch. That seems like it would be quite a lot of work so I was wondering if there is any 5spd trans. that has a mechanical clutch that would work.
Any info would be greatly appreciated thanks!!
71ChevyCheyenne is offline   Reply With Quote
Old 03-13-2017, 01:07 PM   #2
Jcfcamaro
Jcfcamaro's Avatar
Re: 1971 C10 5spd swap
Tremec TKO 600
Jcfcamaro is offline   Reply With Quote
Old 03-13-2017, 01:13 PM   #3
71ChevyCheyenne
I should also mention I'm on a limited budget and looking for a trans. that I could find in a junkyard to use.
Old 03-13-2017, 01:35 PM   #4
SeniorVerde
SeniorVerde's Avatar
I put an Nv3500 in my '67 and kept the mechanical clutch.
It was a while ago, so I don't have part numbers or kit references handy, but it can be done.
SeniorVerde is offline   Reply With Quote
Old 03-13-2017, 01:58 PM   #5
Overdriven
T5 but they can get complicated. Lots of research needed with all the different models and shifter location options plus they can't take much abuse.
Overdriven is offline   Reply With Quote
Old 03-13-2017, 02:07 PM   #6
71ChevyCheyenne
Thanks for the response. I would definitely like to keep the mechanical clutch if I knew how and what parts to use.
Old 03-13-2017, 02:09 PM   #7
71ChevyCheyenne
I've looked into the s10 t5's as well and the majority of people say the can't handle much.
Old 03-13-2017, 03:37 PM   #8
Wrenchbender Ret
I've put in several T-5 from S-10,s with 350 engines & haven't torn one up yet. If you drive it right it will hold up.
Wrenchbender Ret is offline   Reply With Quote
Old 03-13-2017, 03:42 PM   #9
Overdriven
The Camaro T5 is better but still not a performance transmission plus the shifter is far back on it. Preferred T5 setup is a hybrid of Camaro front half and internals with some S10 parts to move the shifter forward. Or get an S10 T5 and have it stuffed with good internals, either way if you have it built you're basically at TKO price.
Old 03-13-2017, 05:06 PM   #10
71ChevyCheyenne
I think I'm leaning more toward looking for a Nv3500. Do you guys have any information as far as switching to a hydraulic clutch? Or how I could use a mechanical clutch? If I found a truck at the junkyard couldn't I take the transmission and the clutch master cylinder from the same truck and make it work in mine?
Old 03-13-2017, 06:45 PM   #11
88Ironduke
I just passed on a NV3500 myself. The mounting of the starter on my 250 requires a bell housing for such and the NV3500 becomes a non-starter (no-pun) item.
Paul
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 03-13-2017, 07:42 PM   #12
LockDoc
The Older Generation
LockDoc's Avatar
Everything you ever wanted to know about installing 5 speed overdrive transmissions....
http://67-72chevytrucks.com/vboard/s...d.php?t=438224
If you think you want an NV4500 5 speed overdrive to replace your SM465 check this thread out. Keep in mind that the NV4500 is more of a work truck transmission, It still has the granny low 1st gear but it also has overdrive.(the best of both worlds) You start out in 2nd gear and only use 1st when pulling a trailer or stumps...
http://67-72chevytrucks.com/vboard/s...d.php?t=673588
LockDoc
Leon
Old 03-13-2017, 10:18 PM   #13
kehstr
kehstr's Avatar
LockDoc
the nv4500 is more less a sm465 with overdrive. My recommendation would be to add a nv3500 unless you plan on towing a lot with your truck
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 03-13-2017, 10:24 PM   #14
Husker
Husker's Avatar
I am gathering the right stuff to put a S10 T5 mechanical speedo in My 68.
Good info in above links and here also.
Ron
http://lugnutz65chevystepside.weebly.com/
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
nv3500 swap, transmission change
