Old 03-21-2017, 04:57 PM   #1
63C20
63C20's Avatar
original accelerator linkage to new style conversion? * SCORE *!!
I need to know how to convert to the new style with kickdown from old rod style?
63C20 is offline   Reply With Quote
Old 03-21-2017, 10:20 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: original accelerator linkage to new style conversion?
Dont know if this helps?
DPowers is offline   Reply With Quote
Old 03-22-2017, 07:09 AM   #3
PGSigns
PGSigns's Avatar
That Q jet has the cable type ends on it. You can swap to a cable pedal for that part. What trans is in it? There are threads on doing the cable throttle swap. I am getting ready to do it on my 66.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-22-2017, 09:48 AM   #4
64shortbox
64shortbox's Avatar
63C20,
Another way to accomplish this is to use a factory bracket off ANY GM vehicle with a Quadrajet carb and a turbo 350. I don't know how many carbureted cars are still in the junk yards but that's what I did on my 350/350 64 C-10. The bracket just mounts on the back of the carb and uses the 2 back carb mounting bolts to mount the bracket.
64shortbox is offline   Reply With Quote
Old 03-22-2017, 01:31 PM   #5
63C20
63C20's Avatar
Originally Posted by 64shortbox View Post
63C20,
huh? i need to know how to convert the rod to my carb
Old 03-22-2017, 01:33 PM   #6
63C20
63C20's Avatar
ya see if i had a outer rotating assembly that had a hole id do that but i have studs
Old 03-22-2017, 04:39 PM   #7
forestb
forestb's Avatar
On my q-jet I used a threaded rod with a heim joint on each end. One side connected to the rod that comes off of the peddle and the other connected to the carb. I think that the stud that has the center line going to it in your photo will unscrew and there will be a hole there. The problem I had when I did that is that I never felt like I was getting full rotation out of the throttle on the carb. It will get you on the rode but it might not give you full throttle. If you can figure out a way to get a rod to hook on to the top stud in your photo I think you will be in business.
I ended up installing a Lokar peddle and linkage in my truck. But that was done while having my firewall smoothed so it was easy to fill in the old holes and add new ones.
forestb is offline   Reply With Quote
Old 03-22-2017, 10:14 PM   #8
64shortbox
64shortbox's Avatar
63C20,
Sorry I misread your question. As forestb suggested, I would use heim joints at each end with all thread rod connecting something light but #10-32 internally thread heim ends is about the smallest I've found. MCmaster-Carr lists them as Ball Joint Rod ends. Here's some from McMaster-Carr
https://www.mcmaster.com/#ball-joint-rod-ends/=16vexnt
McMaster-Carr does sell to the public as does Graingers now.
Old 03-22-2017, 10:54 PM   #9
forestb
forestb's Avatar
Yes they do. I have bought stuff from then several times.
63C20,
Old 03-23-2017, 06:10 PM   #10
63C20
63C20's Avatar
SCORE! trip to the boneyard and now im all OE 1981, got a pedal assembly cable and quadrajet bracket
Old 03-23-2017, 07:29 PM   #11
63frankintruck
there is a very good thread somewhere on this site for installing that type pedal in our old trucks
63frankintruck is offline   Reply With Quote
Old 03-23-2017, 07:34 PM   #12
The Rocknrod
Moderator
The Rocknrod's Avatar
I believe this is the one:
http://67-72chevytrucks.com/vboard/s....php?t=530828\
Old 03-23-2017, 07:34 PM   #13
63frankintruck
[QUOTE=63frankintruck;7894707]there is a very good thread somewhere on this site for installing that type pedal in our old trucks
Here ya go hope this helps ya
http://67-72chevytrucks.com/vboard/s...00#post1383300
Old 03-23-2017, 07:39 PM   #14
63C20
63C20's Avatar
thanks. sadly mine doesnt have the predrilled holed and nuts so ill just drill my own
