#726 |
Re: 68 project
Hey man ![]() 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
#727 |
Re: 68 project
Wait ,when did the K20 happen ? Where have I been to miss that one ?
#728 |
Re: 68 project
I'm still digin that bumper. Guess I'm a fan of the small subtle things that set em apart. We get much more rain its gonna come in your doors on that thing.
#729 | |
Re: 68 project
That LS i see in the k-truck is a 6-bolt so just take the two and average them.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
#730 | |
![]() Join Date: Jun 2009
Re: 68 project
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#731 | |
Re: 68 project
![]() I may go with a set of splayed caps, just seems to be cheap insurance for something you are pouring your life savings into. http://www.ebay.com/itm/331724313895
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant Last edited by GR8-68; 04-25-2017 at 06:05 AM. |
#732 |
![]() Join Date: Dec 2012
Re: 68 project
Larry,
Here is my opinion man. You will be fine with your 2 bolt block, even with the 3.750 stroke. I would use ARP studs instead of the stock bolts and you will need to line hone the mains. At your power level, it will be plenty strong.
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
#733 | |
Re: 68 project
but just remember you can likely find a short block 4 bolt 350 for the price of those caps!
keep on building. http://67-72chevytrucks.com/vboard/s...d.php?t=680094 2017 GMC Canyon diesel 1968 Chevrolet C20 ![]() 1970 Mercedes 280S (WTB 1968 4wd barn door suburban) |
#734 |
Re: 68 project
Thanks for all the input, a bit of history on this block I have is that it was just recently already built and is freshly bored to 4.030, it still has the crosshatching showing. So by using this I will actually be saving some on machine work.
#735 |
![]() Join Date: Mar 2011
Re: 68 project
hey Larry, question if your going to run a 700R4 or a 400 tranny i think they are the same length ....can you take a measurement for me from either the forward cab mount rear rivet hole to the first rivet hole for the trans cross member I'm running a cpp trans member...thats the only one I'm not quite sure where it should be positioned or a measurement from the engine cradle back or any position/measurement to get me lined up my plan is to attach all the cross members to one rail then bring the other rail in to attach so I'm not sliding them in on an angle making scratches....if that makes any sense
thanks Jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 04-27-2017 at 10:14 PM. Reason: spell check:) |
#736 | |
Re: 68 project
#737 |
Re: 68 project
no rush thanks
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#738 |
Re: 68 project
No updates right now, putting my next strategic plan together as I am hitting another expensive hump in the road as I put my motor and tranny package together. Somehow seems to be everything I want is at least 600 or more.
![]() ![]() ![]() My 600.00 ignition system should be arriving this week. ![]()
#739 |
Re: 68 project
couldn't you just go electronic speedo and save about $520?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
#740 |
Re: 68 project
If I could find one that looked identical to the factory speedo yes, but everything electronic you see for these trucks looks absolutely nothing like factory guages. I am trying to keep mainly factory look on the dashboard. Most of the electronic guages are not to cheap neither.
#741 |
Re: 68 project
#742 |
Re: 68 project
Off with the old in with the new
#743 |
Re: 68 project
Everything costs money no matter what we do. Oh well. Cost to just spin a wrench. I always thought racing was expensive but sometimes our trucks can be costly. Lol. At least you'll be able to drive your truck more than just on a Saturday.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#744 |
Re: 68 project
Larry, I just read over your build thread. You have come a long way man. Your truck is really looking great. If you are ever down Tennessee way, drop by and see Chad and me.
Good luck bud. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
#745 | |
Re: 68 project
I was particularly referring to this thread http://67-72chevytrucks.com/vboard/s...d.php?t=512751 I have done the conversion, and it looks perfect!
#746 | |
Re: 68 project
Thank you for taking the time to read my build, I would definitely like to come by some time. Thanks for the invite, same for here.
#747 |
Re: 68 project
#748 |
Re: 68 project
#749 |
Re: 68 project
The new Lunati cam and lifters are on the way and the stroker kit should be here next week
#750 |
Re: 68 project
The new rear ride height is perfect! !!
