Old 02-04-2017, 11:39 PM   #1
jpgl
spare tire carrier
i purchased a 1970 chev longhorn yesterday underneath the rear there is a spare tire carrier it is on the option list. is this a option that came on 1/2 tons and is it rare? thanx for any info
jpgl is offline   Reply With Quote
Old 02-05-2017, 03:17 AM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: spare tire carrier
Probably not so rare. You might plug in the option code into search, see what you get.
It's not on the SPID on my 72, but it's Super, so I suppose it has everything anyway.
My 71 Custom Deluxe shows it, but it's a P13, which is an in bed carrier.
On a side note, some day I'll get under that 72 to determine how that thing works. Looks like a real pain, especially the state of the bolts. At least one is bent. From this angle the in-bed carrier is more better.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-05-2017, 10:07 AM   #3
Myoldtruck
Myoldtruck's Avatar
My 70 has it but I tried to get my new spare tire on it and pulled up. No luck at all to get it up and secured. I installed a bed mount for the spare.
Myoldtruck is offline   Reply With Quote
Old 02-05-2017, 11:34 AM   #4
100%Chevy
My 68 has one in the bed(on the spid) and one under the bed too(not on the spid)!
Was the one under the bed standard equipment by 68?
Mike.
100%Chevy is offline   Reply With Quote
Old 02-05-2017, 11:37 AM   #5
Jcfcamaro
Jcfcamaro's Avatar
What does Spid stand for?
Jcfcamaro is offline   Reply With Quote
Old 02-05-2017, 11:41 AM   #6
B. W.
B. W.'s Avatar
Service Parts IDentification plate
B. W. is offline   Reply With Quote
Old 05-16-2017, 05:45 PM   #7
OhCookie
OhCookie's Avatar
How do you know if your truck came with a spare tire and/or carrier? I'm new to these trucks, I am more familiar with my 1970 Camaro. My truck is missing the SPID so I can't look there and I didn't see anything underneath.
OhCookie is offline   Reply With Quote
Old 05-16-2017, 06:46 PM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Mike.
Yes. Standard for 1968 MY.
I had to remove mine for a Class III hitch.
The stock spare rests on brackets in the underbed brace, hung from a long bolt on the drivers side, and on the passenger side, a long bolt w/special nut with a 1'' reinforced ring goes thru a 'keyhole' in the brace and holds it up. A chain with a padlock was the best way to secure it.
Does not play well with aftermarket rims and tires.
Tubeless tires can lose the rim seal and depressurize [go flat] while slung under during rough-roading.
Best way [if you're not 26 anymore] to return tire to stowed position was with a small bottle jack.
Old 05-16-2017, 08:40 PM   #9
100%Chevy
I have a class III hitch on mine.It fits well with the P-235-75-15 tire.
I pull a 18' car trailer with it.
Mike.
Old 05-16-2017, 11:27 PM   #10
mike16
My truck, 72c10, came with the spare tire carrier in the bed. It has been there from day one. Its not on the SPID. Nor Has the the under bed carrier been mounted, and it too is not on the spid. I dont know if a spare was an option back then.
Quite a few of the in bed tire carries here in the the south west. Gave a bit more ground clearans on the many undeveloped roads that were common back then.
the carrier itself is not that hard to find. Its the little bits of hardware that goes with it that always gets lost . Do a search because it was discussed before and somebody had all the actual hardware.
They would vibrate loose. and thats when the hardware goes missing.
On 3/4 ton trucks I believe spares were an option so tire carrier were based on that. And I suppose a choice where to hang the spare
currious thing is that my 68K20 has the under bed carrier while my 72c10 has it up in the bed. Nothing on either Spid refferences a spare or mounting .
mike16 is offline   Reply With Quote
Old 05-16-2017, 11:39 PM   #11
El Dorado Jim
it is the sheet that is on the inside of your glovebox
El Dorado Jim is offline   Reply With Quote
Old 05-17-2017, 01:23 AM   #12
'68OrangeSunshine
Mike.
I have 235/85/R16LTs. Originally 7.00x17.5.
Do you have a longbed, Mike?
My truck is a shortbed stepside.
Old 05-17-2017, 10:22 AM   #13
100%Chevy
Yes,mines a longbed,fleetside.
Mike.
Old 05-17-2017, 05:56 PM   #14
'68OrangeSunshine
Mike.
On the shortbed frame, I ran out of room. Possibly I could redrill 1/2''- 9/16'' holes thru the carrier and frame, and remount the spare hanger set up. Bigger fish to fry for now.
spare tire
