#151 |
60-66 Nut
Re: '60-'62 POwer Brake Booster Adapter Bracket With A Clutch
PM sent
#152 |
![]() Join Date: Sep 2016
I am working on one with the same spring (62 chevy suburban) I have put 2 washers on the lower block on the firewall to change the angle a bit. Just have to figure out the placement on the pedal for the right through length.
#153 |
60-66 Nut
Isn't there another clutch return spring elsewhere, so you can remove that huge spring and bracket? I do not currently have a '60-'62 cab to look at, but I do not recall seeing that spring on all the '60-'62's.
#154 | |
![]() Join Date: Jan 2017
We are adding a 2 washer spacer to change the angle a bit with a longer bolt to keep the original spring and gain the small amount of clearence needed. Should Work fine Ill keep you informed and try to take Pictures. |
#155 |
Here is the mod I made just a small adjustment in the angle, 2 washers width.
#156 |
60-66 Nut
All of my booster brackets now come with slotted booster mounting holes to also accept aftermarket universal boosters with the 2-3/8" x 2-3/8" center to center mounting studs.
#157 |
60-66 Nut
I am officially notifying everyone that I will be on vacation from 02-05-18 thru 02-13-18. I will do my best to get all orders built and shipped before I leave, if placed by 01-31-18. Orders placed while I am gone will be built and shipped in order of receipt of payment once I return. Thanks for understanding.
#158 |
hillbilly
I am using a nv3500 5 spd with internal slave cylinder. The factory master for this slave cylinder is 18mm. I would need a clutch master that matches that. Also i would like to do the lower pedal mod that i have seen many do where it lowers all the pedals. Will your linkage allow for the shorter throw of the clutch since it will be closer to the floor?
-1962 C-10 |
#159 | |
60-66 Nut
I have a .700" bore clutch master in stock. The threaded rod between the clevis and the rod end could be shortened. This depends on how much you are going to move the pedals. In moving the pedals, you will need to maintain the original pedal travel distance. If that is not possible, we may need to increase the bore size of the clutch master.
#160 |
hillbilly
I am sure it will be a shorter throw. Do you think that you could get by with a straight rod going in the clutch master cylinder
-1962 C-10 |
#161 |
60-66 Nut
It is possible but hard to say for sure until the pedal assembly is done and you see what the stroke of the clutch pedal is where the clutch master will have to attach.
#162 |
60-66 Nut
The Wilwood clutch masters went up in price again, so I had to raise my price on this conversion.
#163 |
![]() Join Date: Mar 2006
Hey CaptainFab, I'm finally getting around to installing your power brake booster bracket and have a quick install question. On the clutch bracket that mounts on the inside of the firewall there are two hex shaped spacers welded to the bracket, one is threaded, the other is not. At the tip of the spacers there are small "nubs" - one on each spacer. What is the purpose of these nubs? Do I just tighten the mounting bolts and pull them into the metal on the firewall? I'll attach a couple of pictures so you can see what I'm talking about. Thanks for your help - this is definitely a well made piece!
#164 |
60-66 Nut
I replied to your PM. I am only here on the forum once a day. If you require a quicker reply, please send me an email. I answer all emails 4-5 times a day 7 days a week.
#165 | |
#166 |
60-66 Nut
The notches machined in the ends of the coupling nuts are there for a specific reason. They are machined like that to straddle the double sheetmetal lap joint on the inside of the firewall and keep the pivot mount sitting flat.
#167 |
Man I just noticed where you are Captain Fab. I live in Chewelah Wa. Can a guy come see you and get parts? I definetly need the booster and master cylinder set up for my 60.
Owner Operator at DMC Square Body and Egg Farm. |
#168 |
60-66 Nut
Yes you are welcome to come pick up your order at my shop. But I do not have any products welded up and sitting on shelves. All orders are build in the order received. Due to an overwhelming number of orders, I am currently 25 days out on building and shipping orders. I will need to know what you are using for a clutch slave cylinder or hydraulic release bearing.
#169 |
60-66 Nut
Due to an increase in the cost of having my parts laser cut, I have been forced to raise my prices. I'm not making any more money, just trying to stay in business with these increases in my costs. Thanks for understanding.
#170 |
Great product. Worth every penny!
#171 |
60-66 Nut
Thanks for the kind words, I appreciate the purchase. What diameter is that booster?
#172 |
#173 |
60-66 Nut
How well does your truck stop with that small of a single diaphragm?
#174 |
#175 |
![]() Join Date: Jan 2012
Does anyone have a picture of this part installed?
