Old 07-04-2017, 01:45 PM   #26
Mw548
Re: 1951 long bed build
Got the bed mounts finished as well as running boards mounted yesterday. Started working on brake lines
Mw548 is offline   Reply With Quote
Old 07-20-2017, 04:04 PM   #27
Mains52
I like this build. I am doing a 52' 3600 my bed isn't that long though you must have found a rare extra long bed. Very Cool build I am tagging along for sure.
Mains52 is offline   Reply With Quote
Old 07-20-2017, 04:17 PM   #28
Mw548
Took the driveshaft up to the driveline shop tuesday and had them add a 27 1/2" shaft to the front and a carrier bearing. I now have a two piece driveshaft cuz of the length. I finished welding in the carrier bearing support. I also cut down the factory shift linkage and drilled a a new hole in it. I hooked up the factory shift linkage. Its a little stiff but its actually not that bad for what it is.
Old 07-20-2017, 04:37 PM   #29
Mw548
Old 07-20-2017, 04:43 PM   #30
cooperhw
cooperhw's Avatar
I like it. I also did a 51 about 30 years ago. Lifted it and sat it on a later model 4X4 chassis. Drove it for a couple years to shows and cruises.
Don't hardly ever see a long bed in these years.
Good for you. Project is coming along nicely.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 07-25-2017, 10:06 PM   #31
Mw548
Its alive and moving for the first time!! Still aways to go but def a good feeling
Old 07-26-2017, 01:29 AM   #32
joedoh
joedoh's Avatar
hell yeah!
Old 08-28-2017, 11:18 PM   #33
Mw548
Well its official a little under a year and this truck is on the road. Still have a few things to tidy up but but overall I'm happy with it. I just finished wiring the led light bar in for tailights and rebuilding the steering column to fix the loose tilt. Found one of the bolts came loose and fell inside column which was causing a stiff shift linkage and random binding in steering wheel when turning. Also finished installing headlights and trying to figure out front turn signals.
Old 08-29-2017, 10:57 PM   #34
Mw548
Bed floor in rough still need to attach
Old 10-21-2017, 12:15 PM   #35
Mw548
My water pump was leaking and I decided to replace it. New pump made it 6 miles and the shaft snapped off damaging my radiator and cooling fan. 😡
Old 12-24-2017, 01:26 PM   #36
Mw548
Well with a few things left to do i started to find another project and ran across a 1930 Tudor model a that i decided to build. I know it’s a ford but i have always loved the look of the channeled model a.
Old 12-26-2017, 09:49 AM   #37
gigamanx
Love the Tudor! I was so torn when I was first choosing a car to build between a ratrod tudor or the pickup truck. I love the highboy roadsters. Pretty much anything with the engine sticking out like a hot wheels car. You could still chevy it up with a sbc 350 haha. I chose the truck because I can use it to haul parts for future builds. Oddly I haven't looked at the tudors in some time and I'm not nearly as scared to tackle one as I was a year ago.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 12-26-2017, 08:49 PM   #38
Mw548
The funny part is i went the same way decided to do the truck as well but after having about 95% done on truck saw this and had to snatch it up. Got a great deal and it even had a title
Old 01-18-2018, 10:26 PM   #39
Mw548
Got the body set on the frame about ride height. Did a double z frame with a 4/12 drop. Been craigslisting this week picked out a unique drivetrain. Putting a 472 Cadillac big block turbo 400 trans and a rear end from a 1978 f150.
Old 01-18-2018, 10:30 PM   #40
OutlawDrifter
That Cadillac is a torque monster! Don't over rev it and it will hold together forever. There is actually a great aftermarket for them. With an aluminum intake they weigh close to a SBC.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 01-18-2018, 10:53 PM   #41
Mw548
yea thats what i been seeing. I just wanted something other then a ls or 4bt seems to be pretty common right now figured this looked like a good start. I really dig the distributor hanging off the driver side in the front
Old 01-19-2018, 09:27 AM   #42
gigamanx
Very cool, keep it coming! Are you bagging it or just doing a static drop with the Z frame?
Old 01-20-2018, 10:44 AM   #43
Mw548
I plan on doing air ride on it. Picked up a 1977 9” rear end out of a f150. Had to get pretty wide due to the frame drop the body tapers out as it goes up.
Old 01-28-2018, 07:36 PM   #44
Mw548
Got rear axle cut in now ordered a set of wheels and a 4 link to get it welded in place
Old 02-14-2018, 08:31 PM   #45
Mw548
Got my 4 link and rims delivered started to get axle in place
Old 02-24-2018, 07:52 PM   #46
Mw548
Got all the old motor mounts and trans crossmember cut out getting ready to weld in mounts and trans crossmember for the big block 472 caddy motor and turbo 400
Old 03-24-2018, 12:58 PM   #47
Mw548
Started to fit the big block into the Tudor. I also got the front axle for the car and mocked it up as well
Old 07-10-2018, 07:58 PM   #48
Mw548
Getting the brakes and wheels mocked up making sure the steering linkage clears the motor
Old 11-13-2018, 11:49 PM   #49
Mw548
Welding in 4 link and air bag brackets
Old 11-13-2018, 11:52 PM   #50
Mw548
Pics
