Old 08-04-2017, 05:14 PM   #1
86c10shorty
Finally scored some 15x10 steelies
Name:  steelies 15x10.jpg
Size:  68.5 KB $100 for both!
86c10shorty is offline   Reply With Quote
Old 08-04-2017, 05:59 PM   #2
SkinnyG
SkinnyG's Avatar
Re: Finally scored some 15x10 steelies
Good deal!
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 08-04-2017, 09:47 PM   #3
TrailerTrash
TrailerTrash's Avatar
Thumbs up Re: Finally scored some 15x10 steelies
I am super jealous. it took me quite awhile to find a staggered set of Rally wheels. Best i could find was 2 15x7s and 2 15x8s. really want some 15x10s 15x8s are everywhere around here in 6 lug though
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 08-05-2017, 09:13 AM   #4
abig84
abig84's Avatar
did they actually make 15x10 from the factory? what did they come on?
i know you can get all sorts of aftermarket rims in those sizes, just never seen rally's that wide
abig84 is offline   Reply With Quote
Old 08-05-2017, 12:07 PM   #5
1986swb
1986swb's Avatar
Originally Posted by 86c10shorty View Post
Attachment 1677113 $100 for both!
Great score. I paid $300 for my new from Jegs. 15"x10" rally with 5" backspacing. Running 295-50R Cooper Cobra tires on them. With a 7" rear drop.
The fronts are 15"x7" rally with 245-60R Cooper Cobra tires.
Front and rear, no rubbing at all! Lock to lock turning, no issues. See pics.
What is your backspacing for your new rear rally rims as it will affect your tire sizing in relation to your fender wells?
1986 GMC Sierra Classic C1500 SWB
2006 GMC Yukon Denali
http://67-72chevytrucks.com/vboard/a...hp?albumid=977
1986swb is offline   Reply With Quote
Old 08-05-2017, 12:53 PM   #6
86c10shorty
My BS is 4.5 will that a affect my 6in drop??
Old 08-05-2017, 01:36 PM   #7
1986swb
1986swb's Avatar
It will be really close to the fender lip edge if you run 295 50s unless you roll the lip
Old 08-05-2017, 05:57 PM   #8
st1
st1's Avatar
I just sold my 15x8s for $250 wheels, tires, bands, and caps. If it looks close roll the fender lip and it will give you a little more room. A bat usually does the trick if you don't have the fancy tool they make.
stone sends...
78 GMC Stepside (http://67-72chevytrucks.com/vboard/s...d.php?t=243201)
06 Dodge Charger Daytona R/T
05 Suzuki GSX-R 1000
st1 is offline   Reply With Quote
Old 08-05-2017, 09:01 PM   #9
SkinnyG
SkinnyG's Avatar
On various cars I've used bats, pipes, sockets, breaker bars, whatever size I need to fit in there. Go slow and do a little bit at a time. If you have a ton of Bondo in your fenders, now is the time you will find out.
Old 08-05-2017, 10:02 PM   #10
1986swb
1986swb's Avatar
If you run 275 60R series tires you should be fine and you will not need to roll the fender lips. Keep in mind every tire manufacturer is a little different. Cooper Tires may have a little softer sidewall than BF Goodrich or others. I chose Cooper Tires as they were cool to mount the tires into my rims and let me check clearance. If I was not satisfied we tried a another tire size. This was true for my front rallies. I wanted to run the 15x8 but the offset was just a tad to shallow for the 245 60R tires. Therefore I went with my 15x7 rallies and they fit much better Yes I brought both rim sizes to DT to test fit. They are the best IMO.
Old 08-06-2017, 12:31 AM   #11
1986swb
1986swb's Avatar
Old 08-06-2017, 08:08 AM   #12
86c10shorty
Thanks for all the replies.
