Old 09-21-2017, 11:11 AM   #1
oldusafmsgt
oldusafmsgt's Avatar
60-61 Interior Paint
Has anyone found a good match for the 60-61 Chevy/GMC Charcoal paint used on the dash ? The old lacquer paint codes don't cross over well to modern paint.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 09-23-2017, 03:58 PM   #2
62 Barnfind
62 Barnfind's Avatar
Re: 60-61 Interior Paint
First I want back with fawn color because I could't find anything in that gray that matched. But I should have tried to get something close to that gray. I have only seen one other truck that has it. Now I have white dash and exterior color on everything else.
Here is the only pick I have with the gray.
This is what I have now. I wanted something different but still kept the vintage vibe.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 09-23-2017, 05:05 PM   #3
oldusafmsgt
Thanks. 60-61's were all silver and charcoal interiors, trying to stay as original as possible. The silver is easy, the charcoal not so much. The fawn interiors that came along in 62 are a lot easier to match.
Old 09-24-2017, 12:19 AM   #4
Brad54
Brad54's Avatar
I drove my suburban for 100,000 miles, and there were times the fawn dash reflected badly off the windshield.
My K10 is a '62, but I'm gonna go with the silver interior and black dash from '60/61.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 09-24-2017, 02:18 PM   #5
61K10
61K10's Avatar
I used rattle can hammer paint, dark gray. kinda like gun metal gray. It's not real glossy.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-24-2017, 04:17 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
That is a nice interior.
Old 09-24-2017, 08:16 PM   #7
62 Barnfind
Thanks Rocknrod! The satin white looks good but a pain to keep. I'm always cleaning it.
John Z
62 Barnfind
Old 09-24-2017, 08:17 PM   #8
62 Barnfind
I really love that color! Good Job!
John Z
62 Barnfind
Old 09-25-2017, 12:18 PM   #9
61K10
61K10's Avatar
Thanks. With your custom interior a stock dash wouldn't look right. Yours blends in just right.
1961 chevy K10
Old 09-26-2017, 02:00 PM   #10
oldusafmsgt
61K10, Looks good ! Pretty close to factory.
Old 09-26-2017, 07:29 PM   #11
62 Barnfind
Thanks! I had it stock fawn for a while but I decided to change it. My friend kept beating me with his 56 F100 so I had to change it a little.
John Z
62 Barnfind
Old 09-26-2017, 07:51 PM   #12
rvrfoot
Not bad for rattle can at all.
rvrfoot is offline   Reply With Quote
Old 03-31-2020, 01:02 PM   #13
Ulrik555
Hello,
I'm about to repaint the interior on my 1960 Fleetside and would like som feedback on this:
I'm thinking about going for thease two colors:
Interior: Silver metallic (RAL 9006)
Dashboard: Graphite grey (RAL 9024)
I haven't decides about the glossiness yet, but I'm thinking about gloss 20 (it's rather flat)
I found an untoched spot of silver metallic behind the ID-plate on the left kickpanel. It looks pretty flat to me.
Please comment on this if you have any experience.
Another question:
The front of the glovebox and the gaugehousing and the area underneath is painted silver. Is this the same silver color as on the rest of the cab interior?
Thank you in advance
Ulrik555 is offline   Reply With Quote
Old 03-31-2020, 01:54 PM   #14
jrusher
I used the ppg wa7134 for the silver but it’s abit glossy and the charcoal I used a nason line I’ll have to check the numbers I can’t remember if he scanned my glove box door or used a old code
jrusher is offline   Reply With Quote
Old 03-31-2020, 04:53 PM   #15
Ulrik555
Thank you jrusher
Would be nice if you can find the number for the charcoal.
Some have grey steering wheel and column and others have silver.
I don't know if both where original alternatives, but i'm gonna paint my steering wheel and column silver met.
This is the old "original" paintnumbers for the interior 60-61 (maby others years aswell?)
If anybody has sucessfully translated thease to modern numbers (recepies) i would be more than happy if you could share them.
How about glossiness?
Interior - silver gray
DUCO MM313
DuPont 94162
Diamont WA7134
Dash top - charcoal gray
DUCO 73605
DuPont DS 174
Old 03-31-2020, 10:35 PM   #16
jrusher
No problem . I’ll get that nason code for the charcoal tomorrow I’m just on nites. I think it’s a close match . My steering column was charcoal/grey as well . The silver like I said earlier color wise i think is close but had too much shine I should of dulled it down. It’s a patina truck on the outside so good enough .
Originally Posted by Ulrik555 View Post
Thank you jrusher
DUCO MM313
DuPont 94162
Diamont WA7134
DUCO 73605
DuPont DS 174
Old 04-01-2020, 08:39 AM   #17
60-66
60-66's Avatar
Charcoal steering wheel and column is 1960 only. 1961 is when they switched to silver on the column and wheel.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 04-01-2020, 02:45 PM   #18
jrusher
My 61 was charcoal wheel and column . Maybe cause it’s a Canadian truck
Old 04-01-2020, 03:38 PM   #19
Ulrik555
Thank you all for commenting
I will put up som pictures on my interior when it's painted.
I'm still curious about the glossiness.. was the original interior paint closer to semi-matt, then semi-gloss?
Old 04-01-2020, 11:11 PM   #20
jrusher
Here’s the nason number . Hope that helps you out
Thank you jrusher
DUCO MM313
DuPont 94162
Diamont WA7134
DUCO 73605
DuPont DS 174
Old 06-08-2020, 08:07 PM   #21
G8rN@te61
Did the removable door panels come same color as interior or was it an alternate color to match exterior or something?
G8rN@te61 is offline   Reply With Quote
Old 08-13-2020, 09:02 AM   #22
jbgroby
jbgroby's Avatar
Same Color on the GMC's
jbgroby is offline   Reply With Quote
