Re: 60-61 Interior Paint
Thank you jrusher
![]() Would be nice if you can find the number for the charcoal. Some have grey steering wheel and column and others have silver. I don't know if both where original alternatives, but i'm gonna paint my steering wheel and column silver met. This is the old "original" paintnumbers for the interior 60-61 (maby others years aswell?) If anybody has sucessfully translated thease to modern numbers (recepies) i would be more than happy if you could share them. How about glossiness? Interior - silver gray DUCO MM313 DuPont 94162 Diamont WA7134 Dash top - charcoal gray DUCO 73605 DuPont DS 174 |
#2 | |
No problem . I’ll get that nason code for the charcoal tomorrow I’m just on nites. I think it’s a close match . My steering column was charcoal/grey as well . The silver like I said earlier color wise i think is close but had too much shine I should of dulled it down. It’s a patina truck on the outside so good enough .
![]() ![]() Join Date: Apr 2012
Charcoal steering wheel and column is 1960 only. 1961 is when they switched to silver on the column and wheel.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Thank you all for commenting
![]() I will put up som pictures on my interior when it's painted. I'm still curious about the glossiness.. was the original interior paint closer to semi-matt, then semi-gloss? |
#6 | |
Here’s the nason number . Hope that helps you out
