07-03-2018, 11:49 AM | #1 |
68 C10 frame damage
Possibly a noob question, but this frame has obviously been hit and I’m wondering if bends/damage like this can be corrected? Again sorry if this is an easy yes or no, I just have zero experience with framework.
1953 Kaiser Manhattan “Sled” 1968 C10 CST LWB 1991 Trans Am GTA “White Nasty” 2006 Dodge Charger RT Built TH400 for Sale |
07-03-2018, 12:06 PM | #2 |
Re: 68 C10 frame damage
If your talking about the rear cross member being bent I don't think it was hit . Looks like someone hooked a chain to it and pulled on it. I would think you could replace that crossmember with a straight one and it would be fine
07-03-2018, 12:50 PM | #3 |
What about the piece ahead of it? Is that bend normal?
07-03-2018, 12:53 PM | #4 |
That crossbar is angled slightly from the factory.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
07-03-2018, 01:19 PM | #5 |
07-03-2018, 03:18 PM | #6 |
I'm picturing someone hooking to a tree stump with some slack in the chain and flooring it.
07-04-2018, 05:50 AM | #7 |
But it works! lol....
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
07-04-2018, 07:45 AM | #8 |
BlahBlahBlah
Super common to see those bent like that. I had a board member come out and pick up a bare frame from me. Used that cross brace to pull it onto the car trailer. It bent. He was like ... Gah I knew better than that to use that to pull on.
07-04-2018, 08:58 AM | #9 |
I have one of those if you need it. I see you also have overload springs there. I am interested in those if you are taking them off for any reason.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-10-2018, 07:07 AM | #10 |
I found it.
07-20-2018, 08:47 AM | #11 |
Just surface rust. Still want it?
