68 C10 frame damage
Possibly a noob question, but this frame has obviously been hit and I’m wondering if bends/damage like this can be corrected? Again sorry if this is an easy yes or no, I just have zero experience with framework.
1953 Kaiser Manhattan “Sled” 1968 C10 CST LWB 1991 Trans Am GTA “White Nasty” 2006 Dodge Charger RT Built TH400 for Sale |
![]() Join Date: Jan 2015
Re: 68 C10 frame damage
If your talking about the rear cross member being bent I don't think it was hit . Looks like someone hooked a chain to it and pulled on it. I would think you could replace that crossmember with a straight one and it would be fine
What about the piece ahead of it? Is that bend normal?
![]() Join Date: Dec 2013
That crossbar is angled slightly from the factory.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
I'm picturing someone hooking to a tree stump with some slack in the chain and flooring it.
But it works! lol....
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
BlahBlahBlah
Super common to see those bent like that. I had a board member come out and pick up a bare frame from me. Used that cross brace to pull it onto the car trailer. It bent. He was like ... Gah I knew better than that to use that to pull on.
I have one of those if you need it. I see you also have overload springs there. I am interested in those if you are taking them off for any reason.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
I found it.
Just surface rust. Still want it?
