Old 08-25-2018, 12:12 AM   #1
MARTINSR
MARTINSR's Avatar
Can someone grab a measurement on the running board braces for me?
The rear running board braces on both sides look like they are bent forward. They aren't even, let me put it that way. The front to the middle brace measures perfect between the inner and outer bolt holes for the running board. Where the rear ones to the middle one don't. The outer ones are closer together than the inner ones.
But they look identical side to side! My running boards are very hard to get to, could one of you guys throw a measurement at those outer holes between the rear brace and the center brace for me?
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 08-25-2018, 01:13 AM   #2
MARTINSR
MARTINSR's Avatar
Re: Can someone grab a measurement on the running board braces for me?
I did just realize that I am going to the Goodguys tomorrow and will have 25 trucks to measure, sorry.
Brian
1948 Chevy pickup
Old 08-25-2018, 07:25 AM   #3
mongocanfly
mongocanfly's Avatar
Maybe this'll help.....
1st pic is from rear support inside holes
2nd pic is center support inside holes
3rd pic is to front support inside holes
4th shows angle of rear pad against the outside lip of the running board.........
The center and front support pads are perpendicular to the outside of the running board
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-25-2018, 07:37 AM   #4
mongocanfly
These pics are the outside running board pattern..
1st pic rear support pad
2nd pic center support pad
3rd pic front support pad
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-25-2018, 10:56 AM   #5
Keystoner
According to this post showing the assembly manual, the rear bracket is shown on an angle.
Although you can't see the numbers, they are:
from bracket #1, measurement showing from both holes, to bracket #2,
both holes, are 31.062 + or - .062.
bracket #2 to bracket #3, using inner hole only on bracket #3,
is 27.438 + or - .062.
The measurement on #3 bracket doesn't use the outer hole,
which shows it on the angle.
Keystoner is offline   Reply With Quote
Old 08-25-2018, 11:40 PM   #6
MARTINSR
MARTINSR's Avatar
Thank you SOOOOO MUCH! If you read my post in the "What did you do with your truck today" thread I didn't have a good day and I didn't get out to the Goodguys (drove right by it though to get my son) and you solved my issue. Thank you so much!
I thought the "damage" looked to symetrical, but they looked bent forward. My frame running board brackets measure out perfectly thanks to you I know they are good.
Brian
1948 Chevy pickup
