Can someone grab a measurement on the running board braces for me?
The rear running board braces on both sides look like they are bent forward. They aren't even, let me put it that way. The front to the middle brace measures perfect between the inner and outer bolt holes for the running board. Where the rear ones to the middle one don't. The outer ones are closer together than the inner ones.
But they look identical side to side! My running boards are very hard to get to, could one of you guys throw a measurement at those outer holes between the rear brace and the center brace for me? Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
Re: Can someone grab a measurement on the running board braces for me?
I did just realize that I am going to the Goodguys tomorrow and will have 25 trucks to measure, sorry.
Brian
![]() ![]() Join Date: May 2015
Maybe this'll help.....
1st pic is from rear support inside holes 2nd pic is center support inside holes 3rd pic is to front support inside holes 4th shows angle of rear pad against the outside lip of the running board......... The center and front support pads are perpendicular to the outside of the running board
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 08-25-2018 at 07:34 AM. |
These pics are the outside running board pattern..
1st pic rear support pad 2nd pic center support pad 3rd pic front support pad
According to this post showing the assembly manual, the rear bracket is shown on an angle.
Although you can't see the numbers, they are: from bracket #1, measurement showing from both holes, to bracket #2, both holes, are 31.062 + or - .062. bracket #2 to bracket #3, using inner hole only on bracket #3, is 27.438 + or - .062. The measurement on #3 bracket doesn't use the outer hole, which shows it on the angle. |
#6 | |
I thought the "damage" looked to symetrical, but they looked bent forward. My frame running board brackets measure out perfectly thanks to you I know they are good. Brian ![]() ![]() ![]() ![]() ![]()
