![]() Join Date: Jan 2018
WTB front drive shaft
Looking for a replacement driveshaft for my '79 K10.
Bruce 70 Chevy C10 SWB Stepside |
Re: WTB front drive shaft
need way more info buddy .
trans t-case 4 bolt flat or yoke style output off t-case liftkit = length difference best to measure end to end .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Sorry, still a newbie... Transmission is a TH350, not sure on the transfer case, will have to crawl under it later.
It is a 4 bolt flat style and the one I have now measures 26.5" between the u-bolts on the shaft itself, and I added the 3.25" for the furthest u-bolt, so 29.75" total from the end u-bolts. Hopefully the pic helps too. Thanks!
The transfer case is the NP203, full-time 4wd model.
Hi Bruce. I have a couple good ones. I'm traveling until the 24th. Hopefully something pops up sooner, if not I will get you pics when I get back to my shop. Thanks, Harlow
thinair
![]() Join Date: Jun 2004
I have to stop out at the shop after work tonight. I'll look and see if there are any extras.
Thanks Harlow!
Matt - if you still have my number, just shoot me a text with a pic of what you have if it is the right length.
It looks like you just need to redo/replace the double cardan assembly. Is that the case? Is the ball still good on the main shaft? If that's the case, any GM squarebody double cardan assembly with flat flange 77-91 could be a donor for repair.
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher 85 K30 SRW 350 TH400 NP205 4.10 87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher 83 K2500 350 TH700R4 8600GVW Dual Tank 4.10 1973 Cheyenne Super 30 DRW Std Cab Z83 4.10 1976 Silverado C30 Std Cab 4.10 DRW (4 sale) |
It looks like it has seen better days. I need to probably replace the ujoints too, so if I could find the whole setup in good shape, it will address both issues.
Tags |
driveshaft |
