01-11-2019, 01:26 AM | #76 |
Re: GM connect and cruise engine package
Guess no one uses mufflers? Stainless or?
OLDIRONRACING |
01-11-2019, 11:18 AM | #77 |
On my LS connect and cruise in the 50 I used 2 1/2" pipe with and x pipe and Stainless Works turbo chambered and it dumps in front of rear tires. Mello when cruising with no drone and gets louder more you step on it. very happy with my set up.
1950 3100 5 window |
01-27-2019, 02:02 PM | #78 |
Has anyone used a electric push button e brake?
OLDIRONRACING |
02-04-2019, 09:14 AM | #79 |
Worked on the exhaust this weekend.
OLDIRONRACING |
02-04-2019, 09:15 AM | #80 |
Exhaust
OLDIRONRACING |
02-05-2019, 03:54 PM | #81 |
Fancy exhaust work, nice!
02-12-2019, 11:54 PM | #82 |
Thanks. Hope to make hangers this weekend
OLDIRONRACING |
02-13-2019, 08:33 PM | #83 |
Is there enough room that the trailing arms won’t come up and hit the mufflers? I was considering tipping my mufflers on their sides to get beside the driveshaft and avoid the trailing arms.
02-14-2019, 09:48 AM | #84 |
With the rear suspension bottomed out there is a 1.5 inc of clearance. Bottomed out means rear end touching the frame.
OLDIRONRACING |
02-14-2019, 09:50 AM | #85 |
Has anyone run in to problems with running the exhaust under the trans crossmember with a 4-6 drop?
OLDIRONRACING |
02-16-2019, 11:20 AM | #86 |
A guy with a truck
Yes, you will drag it, or worst case, it looks ugly hanging down under the cab. Try an Early Classic, CPP, or similar type and route over it, or weld in humps using steel pipe
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-16-2019, 12:08 PM | #87 |
I bought a straight across crossmember before realizing it would be a problem with exhaust routing. I modified it with the half pipes that are raised up with some flat pieces. I have the same kind of pipe pass throughs at the trailing arm crossmember as you.
07-18-2024, 12:50 AM | #88 |
Reviving an old one. Those with connect and cruise or ls swaps. What front accessory drive setups did you go with?
08-04-2024, 02:12 AM | #89 |
On my LSA swap I used an LSX concepts accessory drive.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
08-04-2024, 04:24 PM | #90 |
I use the 2002 Camaro FEA. Some of the stock brackets are no longer available from GM. So I go with ICT.
08-05-2024, 08:06 AM | #91 |
I used the stock F-body front drive set-up.
I was able to get the Sanden AC compressor to mount down low and out of sight using the Alan Grove bracket.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
09-30-2024, 02:35 PM | #92 |
The truck has been running and put 400 miles on it. Got a po690 code the other day. The relays in the fuss and relay box that come with the kit is getting hot to the point you can’t touch them. Has anyone had this problem?
OLDIRONRACING |
09-30-2024, 02:50 PM | #93 |
Pictures of box
OLDIRONRACING |
