11-17-2017, 12:33 AM | #1 |
GM connect and cruise engine package
Has anyone used a connect and cruise engine from GM? Your good or bad experiences with it. Looking at one for my 72 truck.
OLDIRONRACING |
11-17-2017, 01:24 PM | #2 |
Re: GM connect and cruise engine package
I have, the LS3 and 4L60E package. In the middle of putting the truck back together, so I haven't fired it up yet. But, overall, the packaging, instructions, etc. have all been pretty good. If there is a negative, it's more on me than the connect and cruise setup. I ended up using aftermarket front drive assembly components (AC, brackets, etc.) more so than the the GM ones that I paid for.
11-17-2017, 09:59 PM | #3 |
Would like to see and hear more about the install progress. Really thinking I won't to do this. But I'm just know learning about this LS stuff. I don't won't to buy someone else wore out stuff. Hear a lot about the 5.3 and 6.0 LS truck motors and what you can do with them. Not sure where to spend smart money. If I try to do one of the truck motors Am I going to have the same money in it buy the time you change the came,intake,wiring harness and programming? Did you have to change the oil pan on the LS3 to fit the truck and if you did what did you use?
OLDIRONRACING Last edited by Oldironracing; 11-18-2017 at 10:03 AM. Reason: Add something |
11-20-2017, 10:58 AM | #4 | |
11-20-2017, 01:33 PM | #5 |
I went with just the LS3 engine (whatever they call that package) which is the same but without the trans, obviously. But it includes the controller and instructions and all of that.
I think it's a great way to go.
11-23-2017, 10:08 AM | #6 |
Found the best price at Nesmith Chevrolet in Ga. $11,930.00 free shipping. Where are you guys locating the fuse box,ecm and trans controller? They said I could order it with the truck pan #19212593. What are your thoughts on this? Will headers help that much with HP gains? Thanks for all the help that y'all give this LS stuff is new to me. Happy Thanksgiving
OLDIRONRACING |
11-23-2017, 11:46 AM | #7 | |
Posted via Mobile Device |
11-23-2017, 03:26 PM | #8 |
You can order everything through Summit racing same price & free shipping . The LS3 pan will not work without notching the crossmember ( that is what I did to keep the 8 qt pan. ) CTS-V Cadillac is the best choice , truck pan hangs a little low.
11-23-2017, 04:33 PM | #9 |
I found a true 5.7L all aluminum LS1 out of a 2002 trans-am with about 100K miles......it was still in the car and I actually heard it running and drove it before the guy pulled it....
it came with the 4L60E that I traded for a 4x4 version as it will be going in my K/5 Blazer..... I got everything with it including an uncut harness which I have already had converted......got the cruise control module too the whole set-up cost me around $3000 after getting the harness reworked and the PCM re-flashed.... my thought is...... I don't need ground-pounding horsepower....just good performance, economy, and reliability.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
11-24-2017, 12:31 PM | #10 | |
OLDIRONRACING |
11-24-2017, 11:28 PM | #11 | |
Senior Moment
Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 12-14-2017 at 10:37 AM. |
11-25-2017, 03:37 PM | #12 |
For my 1955.2 truck I sourced an LQ4 6.0 LS truck motor and a 4L80E trans for a total of 1300.00 off of Craigslist. Had the included PCM and engine harness reworked for $400. It needed cleaned up, but starts and runs perfectly for a total sum of $1700.
11-25-2017, 10:14 PM | #13 |
2 years ago this month I bought a 2004 suburban with a 5.3 / 4L60e for $400 from a local tow yard, was a easy roll over, the guy was DUI and never came to pick it up. I drove it onto the trailer to get it to a buddies shop where he pulled engine, trans, wire harness, computer, and fuel tank for me. He did all this for me in trade for the left over parts that he then later paid me $500 for. So in reality I was paid $100 to take a 5.3 /4L60e. I bought an oil pan for a 2000 camaro for $160 (ish) and complete billet (bits and pieces) f.e.a.d. system from ITC billet for maybe $500. and a Dirty Dingo A/C mount for another $140. This is definitely the way to go in my opinion.
I have since bought 18 more 99-07 GM trucks for the engine and trans combos, for 3-400 $$ each on average, one was $700 and one was $1.00, I have kept and fixed 5 of those for me and one for my step son. What i am getting at is... craigslist is a great tool, but dont limit yourself to classified ads. Some people dont have the balls to walk up to a house or repair shop that has something in the yard that they want, knock and ask if they are willing to part with said desired item. I will tell you I used to not. I have in the past two years beat on numerous doors and asked if those people want to part with many different cars and trucks and although there is a lot of turn downs, there have been a few nice scores. the VAST majority of the trucks i have bought have come from the local tow and impound yards, granted i used to drive tow truck so i know just about all of the yard owners personally, but if you are patient and make your rounds to the different yards in your willing travel radius you will probably get too lucky. you will find one that fits your bill of needs and probably get a few more calls than you really wanted about trucks or cars that come available after you have already found your donor vehicle. I have a few tow yards that call me about once every other month (combined) to let me know they have a truck or car that is up on lien sale and i have first dibs on it if i am interested. Just saying that the confidence to BEG for crashed or impounded cars is everything when looking for the right donor vehicle.
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
11-26-2017, 12:08 PM | #14 |
I hear all the stores of the great finds have looked and guess I need too just keep looking. Kind of like the idea of all the new stuff and should be right. But you never know.
OLDIRONRACING |
12-24-2017, 05:51 PM | #15 |
Well guys I bought the 500 hp with the hot cam package.
12,000.00 after rebates. Got it from Nesmith Chevrolet in Ga. Should be here in two weeks.
OLDIRONRACING |
12-25-2017, 02:15 AM | #16 |
Merry Christmas to YOU! woohoo have fun with that.
01-06-2018, 12:17 PM | #17 |
I have lc9 65e connect and cruise in my 70 stepper. Been running for over 2 years and love it.
Feels like it has 2 307 engines. Driving back Ga highways at 60 mph got me 22 mpg. Miles were measured by gps so its fairly accurate. |
01-06-2018, 02:52 PM | #18 |
Thanks for reply
OLDIRONRACING |
01-09-2018, 08:53 AM | #19 |
01-09-2018, 10:20 AM | #20 |
Awesome....! keep us up to date on this project...
01-14-2018, 04:22 PM | #21 |
Trans is a 4L70. Will do on the up dates. Been cleaning shop and rearranging getting ready to start. We just finished my sons truck 46 ford bobber truck chevy running gear.
OLDIRONRACING Last edited by Oldironracing; 01-14-2018 at 04:34 PM. |
01-14-2018, 06:30 PM | #22 |
Noticed earlier post said the pan wouldn't fit. The lc9 package went in my 70 with no cutting anywhere and with the supplied pan.
01-19-2018, 09:49 AM | #23 |
Got the call package should be here end of next week
OLDIRONRACING |
01-23-2018, 09:18 AM | #24 |
Here's one done at a verrrry nice level.. Connect and cruise is about 2/3 the way into the thread. Any questions, PM Vic, he's a great guy.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
01-23-2018, 11:27 AM | #25 |
Me thinks you forgot a link.....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
