Old 06-27-2019, 01:42 PM   #26
Jrgunn5150
Re: 73-87 DBW pedal bracket?
Originally Posted by Nodnarb76 View Post
I did. I removed the wire from pin "E" and moved it to pin "A".
I also had to cut a small notch in the connector to make it plug in.
The pedal now is perfect and I have been using it for a couple months now with no issues.
Awesome, I'll have to give that a whirl again, thank you for the pic.
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 06-27-2019, 01:43 PM   #27
Nodnarb76
Nodnarb76's Avatar
Here is a quick video showing it working.
https://youtu.be/tvLE9WGWgYs
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 06-29-2019, 06:32 AM   #28
LeesTruk
Quick question on the sensitivity of the diesel pedal. Is it as quick to react to foot pressure as a truck DBW foot pedal? My truck pedal seems to be too sensitive, meaning the lightest touch causes a response from the throttle body, such as driving on a rough road where the constant bounce will cause your foot to lightly move up/down with body motion. This causing the engine speed to increase/decrease accordingly.
LeesTruk is offline   Reply With Quote
Old 07-02-2019, 11:49 AM   #29
TooTall
Here's my scrap pedal mount. It's at the 3:55 mark.
73 K5 blazer with the DBW pedal mount, using the stock pedal
I used a flat stock of plate, and moved it over 3" and that was it.
https://youtu.be/5oHGKGFrVzw
1984 K10, 8" lift on 35s
2011 Yukon XL | Bone stock
2013 Audi Q5
Old 07-03-2019, 10:56 AM   #30
Nodnarb76
Nodnarb76's Avatar
Compared to the 04 Truck pedal, the 98 Pedal seems more sensitive to me.
The 04 pedal had a lot more travel the 98 pedal. Seems that I don't have to press the 98 pedal as much as I did the 04 pedal.
FWIW: when I had the 04 pedal mounted it sat up really high, and I could not rest my foot on the floor when driving like most cars. So instead of moving just my foot I had to move my whole leg to use the throttle.
Hope this helps.
Old 07-03-2019, 07:43 PM   #31
LeesTruk
hmmmm. Interesting. Because I started with the Tahoe adjustable height pedal, I have gotten rid of all that bridgework, and welded an abbreviated pedal arm to the original pivot. I'm wondering if, because the pedal is so much shorter, the pedal ratio is less than it was, now, it takes less motion to equal the original operation, or maybe, I'm just overthinking it. Anyways, thanks for the response
Old 07-10-2021, 08:57 PM   #32
77c10bowtie
77c10bowtie's Avatar
Likuid kerations Has the absolute best dbw pedal brackets for 60-66 67-72 and 73-87 for all 3 pedal styles. Got one of their 67-72 and 73-87 and they are seriously top quality. I struggled to find a good bracket for 73-87 and now I know there isn't a better bracket out there. Best part is they are only $50 bucks
77 SWB 2wd. gutted, caged, slicks, not weighed yet
02 Duramax CCSB 4x4 12.7@104 6750lbs
77c10bowtie is offline   Reply With Quote
Old 07-19-2021, 07:58 PM   #33
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Gen5 swap - Ive done 2 different pedals. Stock Gen5 truck/Tahoe pedal and while it doesn't look like stock, it doesn't look bad. I still haven't made a metal bracket, still out of 3/4 MDF.
Other I used a 2008 Impala pedal and modified it to use the stock C10 pedal. The Impala needed to have a little sheet metal plate cut out so the pedal would have the stock c10 tilt, otherwise, it was a lot more vertical if i remember, really awkward.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
