Old 12-21-2015, 08:56 AM   #1
Nodnarb76
Nodnarb76's Avatar
73-87 DBW pedal bracket?
What is everyone doing to mount the DBW pedal in there 73-87 trucks?
I've seen Hart Rods killer throttle brackets for the 76-72 trucks and when I contacted him, he unfortunately doesn't make them for our trucks.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 12-23-2015, 11:27 PM   #2
Houston Ben
Houston Ben's Avatar
Re: 73-87 DBW pedal bracket?
Depending on what year you have, I replaced my 2011 truck pedal for a Corvette pedal and used Hart Rod's plate and it works perfect! All I had to do was swap two pins in the plug for the pedal.
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 12-24-2015, 12:52 PM   #3
Nodnarb76
Nodnarb76's Avatar
Are the mounting locations different for each pedal?
Sounds like I'll be getting a pedal from a 03-06 truck (Pedal is still being shipped with the motor so I can't be sure until I get it).
would love to get one of Hart Rod's adapters if it will work. I don't mind drilling if I need to, but as far as cutting or bending the bracket, I'm worried I won't be able to get it right.
Old 12-24-2015, 04:41 PM   #4
Tilt
The '04 DBW truck pedal I used had 2 bolt holes that lined up with the original pedal holes. Haven't had any issues using just two bolts.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 01-07-2016, 02:15 AM   #5
NorCalAnthony
There's a few people using the pedal from a late 90's 6.5 diesel on their Gen III setups. You have to swap a couple of wires in the harness but the pedal itself bolts right up in the 73-87(91) trucks. Here's a pretty good write up on it:
http://api.viglink.com/api/click?for...1%2520swap.pdf
NorCalAnthony is offline   Reply With Quote
Old 01-07-2016, 05:28 AM   #6
wildwilly4x4
I used a '95 6.5 diesel pedal. bolted right in. had to repin the connector on a couple of wires IIRC. Looks completely stock
wildwilly4x4 is offline   Reply With Quote
Old 01-07-2016, 11:58 AM   #7
Hart_Rod
Hart_Rod's Avatar
Good info guys!!! I just added this to my DBW pedal thread so the 73-87 guys can get their conversion done as easily as possible, .
Hart_Rod is offline   Reply With Quote
Old 01-10-2016, 01:25 PM   #8
dman1982
dman1982's Avatar
in my build somewhere i believe i got a pic of my dbw setup, i did some cutting and welding to make mine work, turned out pretty good
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 01-10-2016, 05:18 PM   #9
solidaxel
solidaxel's Avatar
Cut and bend it for Your Foot!
These peddles (DBW) do not have much movement to reach 100% throttle
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-11-2016, 12:04 AM   #10
Nodnarb76
Nodnarb76's Avatar
This is the pedal that came with my swap, what would be needed to bolt it up to my 87 Burb? Do I need to bend the pedal bracket or mod one of Hart Rod's brackets?
Thanks again
Old 01-12-2016, 04:34 PM   #11
Pulse_GTO
What about GEN IV pedals that don't make use of a TAC module?
Pulse_GTO is offline   Reply With Quote
Old 01-18-2016, 10:53 PM   #12
Liltroy
Liltroy's Avatar
http://67-72chevytrucks.com/vboard/s...3&page=1306-07 is a plastic pedal. post 302 shows what I did. Got the idea from glock35. Used the left hand original hole in the bottom pedal hole then drilled a new hole for top pedal hole.
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac
Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303
My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw
Liltroy is offline   Reply With Quote
Old 05-20-2016, 02:40 PM   #13
Nodnarb76
Nodnarb76's Avatar
About to buy the 98 6.5 diesel pedal, if I re-wire the connector like the above link says, this should work with a 2004 gen3 PCM and TAC module right?
Old 05-20-2016, 03:06 PM   #14
Hart_Rod
Hart_Rod's Avatar
What year is your truck and pedal?
Old 06-01-2016, 10:46 AM   #15
Nodnarb76
Nodnarb76's Avatar
Ok bought a new pedal from Rock Auto, instead of taking a chance in screwing up my existing harness, I'm going to see of I can find another pedal harness to buy and modify, just in case something gets messed up.
Old 11-14-2017, 01:03 PM   #16
Nodnarb76
Nodnarb76's Avatar
Bringing this post back from the dead.
I never did try to re-work my pedal/harness wiring. I was too afraid of screwing something up.
Has anyone been able to use one of Hart Rod's 67-72 brackets for a 73-87 truck with a little work?
I have my pedal working in my truck now, but it sits way too high up, and is un-comfortable to drive for a long time.
Old 11-14-2017, 04:06 PM   #17
StingRay
StingRay's Avatar
As I understand it some of the the 72's use the later bolt pattern of the 73-87. The rework is to just drill another hole in the bracket. I think the current ones have both hole sets.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 11-15-2017, 08:50 AM   #18
homemade87
Nodnard76 , This may help. I used an 04 truck pedal . The o4 was a medal bracket . If I remember correctly you had one with a metal pedal arm like I used . I think I used 2 holes that were already there in my 82 to bolt it to the floor . I cut the metal arm off and drilled a hole in it and cut the 82 pedal arm off and inserted it into the 04 arm and set it in place to position it and welded it in place . It is a perfect fit for me . Also looks just like the oem pedal . Heres a couple pictures .
homemade87 is offline   Reply With Quote
Old 11-16-2017, 10:34 AM   #19
Nodnarb76
Nodnarb76's Avatar
That is a good idea, I have a question though as I know nothing about welding.
I am worried that welding my pedal will get the pedal too hot and mess up the electronics in the pedal. Do I not need to worry about that? If not I have a friend who can weld for me and I may end up doing what you did.
Old 11-16-2017, 12:23 PM   #20
homemade87
It was not a problem for me . It was not much more than a tack weld . Once done cool it with water . The electronics was far enough away it did not affect them .
Old 11-16-2017, 01:01 PM   #21
Nodnarb76
Nodnarb76's Avatar
Thank you! I just talked to my friend with the welder and we are going to do this next weekend just like you did. I will post back when I'm done.
Old 01-01-2019, 09:22 AM   #22
dec010974
dec010974's Avatar
hello to all. does anyone have the rewire instruction? i want to try this.
dec010974 is offline   Reply With Quote
Old 04-24-2019, 01:11 PM   #23
Nodnarb76
Nodnarb76's Avatar
I am still looking into what would be the best solution. I currently have the 98 Diesel pedal, and am trying to decided if I should try and re-wire my harness to make it work or cut/weld my existing pedal.
The problem I keep running into, is whenever I find instructions on re-wiring the connector for the pedal, I keep finding other instructions that say to do it differently. I saw a video on youtube where someone only had to swap one wire and he claims his works with no problems.
https://www.youtube.com/watch?v=WX1X...index=2&t=102s
Then I find other instructions that say two wires need to be changed. (second post from the bottom)
https://ls1tech.com/forums/conversio...questions.html
Then I have read about doing it and swapping 3 wires. 4th post from the top
https://ls1tech.com/forums/conversio...91-chevys.html
I am not sure which I should trust.
Old 06-17-2019, 09:40 AM   #24
Jrgunn5150
I'm in the middle of this now, and my pedal isn't working lol. Did you ever figure it out?
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 06-27-2019, 01:40 PM   #25
Nodnarb76
Nodnarb76's Avatar
I did. I removed the wire from pin "E" and moved it to pin "A".
I also had to cut a small notch in the connector to make it plug in.
The pedal now is perfect and I have been using it for a couple months now with no issues.
