Old 01-06-2020, 11:21 PM   #1
bigmoe
bigmoe's Avatar
bed strip bolts size and quantity?
The plan for my 65 short fleet is to hide the bolts that fasten the bed to the frame. I reinforced the cross channels so I can bolt them from below. So my challenge for now is that I don't need to buy a complete bolt kit, I just need the bolts for the strips and the perimeter. I'm going to try to source them (s/s polished). Any suggestion for a source? Also the main reason for this post is I need to know the two sizes and quantities for the strips and around the perimeter. (Assuming they are different?)
bigmoe is offline   Reply With Quote
Old 01-06-2020, 11:30 PM   #2
Lunnb
Re: bed strip bolts size and quantity?
I bought the SS bolts , washers and locknuts on Amazon . I have a long bed step so I needed a bunch for the strips , fenders ,etc and I bought plenty of extra . Total cost was about $80.00
Lunnb is offline   Reply With Quote
Old 01-07-2020, 12:04 AM   #3
bigmoe
bigmoe's Avatar
Do you have the size?
Old 01-07-2020, 12:45 AM   #4
Heater63
Heater63's Avatar
Hardware at McMaster-Carr
Great kits at Mar-K, including hidden fasteners. Outstanding quality. Did a complete brand new bed including wood from them. Not a single bolt head visible in my bed.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 01-07-2020, 04:58 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
If you go with stainless, be sure to use some antiseize compound.
I also went with the MAR-K hidden stainless strip and hardware kit.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-07-2020, 06:13 PM   #6
rcnutt
rcnutt's Avatar
there are 2 sizes for the bed....strips and then the perimeter.....cheaper to buy the kit
64 short fleet
rcnutt is offline   Reply With Quote
Old 01-07-2020, 07:11 PM   #7
Clyde65
Clyde65's Avatar
Totally Stainless has sets
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-07-2020, 10:45 PM   #8
Lunnb
5/16x18x1.5” and 1/4 x20 x1.5”
Old 05-26-2020, 12:02 PM   #9
bigmoe
bigmoe's Avatar
Bought a 315 pc pss kit from LMC. (Doesn't include the big box to frame bolts)
5/16 x 1 1/2" bolt, lock washer and nut - 36ea
1/4 x 1 1/2" bolt, lock washer and nut - 62ea
Also came with 21 x 1/4" extra large washers. Why 21?
Old 05-26-2020, 01:13 PM   #10
cwcarpenter98
cwcarpenter98's Avatar
The extra large washers are for the bolts where they don't go through the cross sills
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-12-2021, 12:43 PM   #11
66_c10
Does anyone know if the carriage bolts that comes in the kits(square carriage bolt) will work with the original bed strips(round hole)? I would like to reuse my original strips, but they were setup for a round and splined carriage bolts that are probably unavailable.
66_c10 is offline   Reply With Quote
Old 02-12-2021, 03:57 PM   #12
bigmoe
bigmoe's Avatar
I bet if you took the strips and tapped a carriage bolt down in each hole the hole would easily take the square shape. You could set each hole over a piece of wood with a 3/8" hole and tap the carriage bolt down.
You might have to drill the strip hole a bit bigger?
Old 02-12-2021, 04:36 PM   #13
SkinnyG
SkinnyG's Avatar
I bought one extra skid strip so I could do composite boards. The single didn't come drilled at all, so I transferred the hole location from on of the drilled strips, drilled all the holes, and then filed the holes square.
It didn't take all that long.
While you're trying to figure out an easy solution, just get started, and before you know it, you're done.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 02-12-2021, 04:44 PM   #14
66_c10
I was just concerned the square carriage bolt would spin in the hole, but maybe not I will try it. If not I will spot weld them in from the back.
Old 04-15-2022, 06:56 PM   #15
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Which of these for just the strips down the middle?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 04-15-2022, 08:32 PM   #16
Killer Bee
Killer Bee's Avatar
there are several different sizes and lengths in a complete kit but this may help you with the hardware assignments you're looking for..
https://www.mar-k.com/PDFs/Instructi...hort-Fleet.pdf
here's the full list if I had the wrong truck model..
https://www.mar-k.com/instructions.aspx
I don't believe mar-k offers their full instructions with diagrams on their website, they only send them when you buy a kit..
but they may be posted somewhere else on the interwebs and I probably have a copy at home somewhere..
if you need it let me know and I'll look for it - good luck!
