bed strip bolts size and quantity?
The plan for my 65 short fleet is to hide the bolts that fasten the bed to the frame. I reinforced the cross channels so I can bolt them from below. So my challenge for now is that I don't need to buy a complete bolt kit, I just need the bolts for the strips and the perimeter. I'm going to try to source them (s/s polished). Any suggestion for a source? Also the main reason for this post is I need to know the two sizes and quantities for the strips and around the perimeter. (Assuming they are different?)
Re: bed strip bolts size and quantity?
I bought the SS bolts , washers and locknuts on Amazon . I have a long bed step so I needed a bunch for the strips , fenders ,etc and I bought plenty of extra . Total cost was about $80.00
Hardware at McMaster-Carr
Great kits at Mar-K, including hidden fasteners. Outstanding quality. Did a complete brand new bed including wood from them. Not a single bolt head visible in my bed.
292 + TKO500 |
It's Better With Nitro
If you go with stainless, be sure to use some antiseize compound.
I also went with the MAR-K hidden stainless strip and hardware kit.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
there are 2 sizes for the bed....strips and then the perimeter.....cheaper to buy the kit
64 short fleet |
![]() Join Date: Aug 2004
Totally Stainless has sets
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Bought a 315 pc pss kit from LMC. (Doesn't include the big box to frame bolts)
5/16 x 1 1/2" bolt, lock washer and nut - 36ea 1/4 x 1 1/2" bolt, lock washer and nut - 62ea Also came with 21 x 1/4" extra large washers. Why 21? Last edited by bigmoe; 05-26-2020 at 12:33 PM. |
![]() ![]() ![]() Join Date: Jan 2018
The extra large washers are for the bolts where they don't go through the cross sills
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Does anyone know if the carriage bolts that comes in the kits(square carriage bolt) will work with the original bed strips(round hole)? I would like to reuse my original strips, but they were setup for a round and splined carriage bolts that are probably unavailable.
I bet if you took the strips and tapped a carriage bolt down in each hole the hole would easily take the square shape. You could set each hole over a piece of wood with a 3/8" hole and tap the carriage bolt down.
You might have to drill the strip hole a bit bigger? |
I bought one extra skid strip so I could do composite boards. The single didn't come drilled at all, so I transferred the hole location from on of the drilled strips, drilled all the holes, and then filed the holes square.
It didn't take all that long. While you're trying to figure out an easy solution, just get started, and before you know it, you're done.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
I was just concerned the square carriage bolt would spin in the hole, but maybe not I will try it. If not I will spot weld them in from the back.
#15 |
But Found Her 25yrs Later!
Which of these for just the strips down the middle?
#16 |
there are several different sizes and lengths in a complete kit but this may help you with the hardware assignments you're looking for..
https://www.mar-k.com/PDFs/Instructi...hort-Fleet.pdf here's the full list if I had the wrong truck model.. https://www.mar-k.com/instructions.aspx I don't believe mar-k offers their full instructions with diagrams on their website, they only send them when you buy a kit.. but they may be posted somewhere else on the interwebs and I probably have a copy at home somewhere.. if you need it let me know and I'll look for it - good luck!
I started out with nothing - and I still have most of it |
| Bookmarks |
