#1151 |
Re: What did you do to your truck today.The 3rd chapter
1976 GMC Sierra Grande,Took the trans tailshaft housing off and re-assembled the speedo drive gear that came loose,I'm guessing the guy that rebuilt it 50k miles ago did not verify that the clip was locked properly. Started it up after re-assy and it looks like it works. Looking for advice on how to clean up and or paint a rusty master cylinder ?
#1152 |
Installed dash pad out of 72 chevy c20 in my 71 gmc. Not perfect but looks a lot better.
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
#1153 |
No picture but I took my truck to a really good alignment guy and he got the truck to drive a lot better. The last guy aligned it and it drove horrible.The bad news is he said it has a 1/4" diamond in the frame. Not surprised! It was a work truck in Alaska the first 30 years of it's life.
68' with no bells or whistles unless I add'em. |
#1154 |
68 C/10
Put my front suspension back together
(2009) GMC Sierra Denali 6.2 AWD (67 C/10 fleetside SWB) (2018GMC Yukon Denali) Wifes Car |
#1155 |
No photos but sprayed my first bit of epoxy primer on the bed steps. Not my best job but at least they won’t rust while I am working on the rest of the truck. Rushed it a bit and got some runs but they will sand out.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#1156 |
Finally finished with the interior. New sound deadner, new carpet, new seat upholstery, and new weatherstripping for the doors. The weather is nice so taking for a cruise on Friday during my day off.
#1157 |
#1158 | |
#1159 |
Mine looked like that. I took some thin foam and wrapped with vinyl from Walmart.
#1160 |
Crimping AC lines
#1161 |
I looked at them .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#1162 |
![]() Join Date: Feb 2009
Had the body built only to find this today
![]() ![]() I went pretty deep on the dry run. Less the upper rear bed, we had the height of the moldings near nuts on both sides without trying. Props to GM, the bodies are well engineered, we made few body alterations. One of the upper bed moldings had bow near center, so we found a happy medium and finished 1/8" off a match at the rear. The front RH door to fender matched within 1/32" where they're supposed to be, I know why, we'll get it right at build. I'm only referring to placement of the moldings, not holes drilled. Ended up shimming the fenders of course, basic cab cushion shims. Front RH cowl panel a whopping 3/16", the RH pillar took 1/8", mix on the LH door striker, and an 1/8" shim at the RH front bed for level and straight. For what it's worth, with new cushions etc. there's a 1" gap between the cab and the top front bed panel. It also measures 3.9" from the rear of the frame rails to the back of the bed floor. I'm interested to know what others find, partially because I need to modify brackets for a rear bumper. Distance from the rear of the frame rails to a sport bumper would be exceptional help. The bed is crooked and the cushions shot on my C20 ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-25-2020 at 04:12 PM. |
#1163 |
![]() Join Date: Jun 2019
Paint test on an old fender. Hugger orange vs Ford lightning blue.
#1164 | |
Disregard the word in front of the lightning but I choose blue Last edited by 66clow; 04-26-2020 at 08:39 AM. |
#1165 |
With the help of my son, We installed the new power steering gear box and rag joint. Took about 2 hours. Easier than I thought it would be.
1971 Chevrolet C20, Blueprint 355. Holly Street Avenger 430HP. Turbo 350 1952 Chevrolet Deluxe. Stock. True survivor with 1 paint job 1953 Buick Special. GM 355. Just a good smooth engine. |
#1166 |
Installed the correct lower radiator hose that clears the belt for my new ac system. Also installed a tach.
#1167 |
![]() Join Date: Mar 2007
Swapped my three gauge idiot light dash to the five gauge dash. Ran new copper oil pressure line. Swapped wires by the instructions on Gmc Paul’s web site. Everything works great.
1968 SWB "Little White Truck" 1972 LWB LS 4l80 "Plain Jane!!" |
#1168 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#1169 |
Finally found a bench seat that was local for my old 1970 that needs to be redone. Well the hard part is over for me, now let the restoration fun begin.
#1170 |
Rear driveline installed...
#1171 |
Still Green but learning
Got the headers installed and the exhaust installed.
https://www.facebook.com/1414494004/...23605315547011
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
#1172 | |
1970 C10 Short Stepper with 71/72 front clip. |
#1173 |
#1174 | |
![]() Join Date: Jul 2015
#1175 |
Re-tubed the washer nozzles, pump run but no squirt. Tackle that at a later time. Slipped the cowl back on with a new seal. Started tearing vent doors apart for paint and new seals.
Installed rear axle bump stop for lowered suspension. Like a dummy I only ordered one and didn’t notice until I opened the box. Discovered my vacuum advance is not working. Always something.
