Old 04-05-2020, 12:48 PM   #1151
kmswi
Re: What did you do to your truck today.The 3rd chapter
1976 GMC Sierra Grande,Took the trans tailshaft housing off and re-assembled the speedo drive gear that came loose,I'm guessing the guy that rebuilt it 50k miles ago did not verify that the clip was locked properly. Started it up after re-assy and it looks like it works. Looking for advice on how to clean up and or paint a rusty master cylinder ?
kmswi is offline   Reply With Quote
Old 04-05-2020, 05:36 PM   #1152
71gmcC15
71gmcC15's Avatar
Installed dash pad out of 72 chevy c20 in my 71 gmc. Not perfect but looks a lot better.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 04-05-2020, 07:58 PM   #1153
Barnfind46
Barnfind46's Avatar
No picture but I took my truck to a really good alignment guy and he got the truck to drive a lot better. The last guy aligned it and it drove horrible.The bad news is he said it has a 1/4" diamond in the frame. Not surprised! It was a work truck in Alaska the first 30 years of it's life.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 04-05-2020, 08:43 PM   #1154
68cajun
68 C/10
68cajun's Avatar
Put my front suspension back together
(2009) GMC Sierra Denali 6.2 AWD
(67 C/10 fleetside SWB)
(2018GMC Yukon Denali) Wifes Car
68cajun is offline   Reply With Quote
Old 04-05-2020, 08:48 PM   #1155
67C10Step
67C10Step's Avatar
No photos but sprayed my first bit of epoxy primer on the bed steps. Not my best job but at least they won’t rust while I am working on the rest of the truck. Rushed it a bit and got some runs but they will sand out.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 04-07-2020, 10:07 PM   #1156
SRU1436
Finally finished with the interior. New sound deadner, new carpet, new seat upholstery, and new weatherstripping for the doors. The weather is nice so taking for a cruise on Friday during my day off.
SRU1436 is offline   Reply With Quote
Old 04-07-2020, 10:19 PM   #1157
SRU1436
Old 04-08-2020, 01:55 PM   #1158
66clow
66clow's Avatar
Depending on how bad, steel brush, Scotch Brite pad, sandpaper, rust converter, paint. Some combination of this.
66clow is offline   Reply With Quote
Old 04-08-2020, 02:00 PM   #1159
66clow
66clow's Avatar
Mine looked like that. I took some thin foam and wrapped with vinyl from Walmart.
Old 04-08-2020, 02:10 PM   #1160
66clow
66clow's Avatar
Crimping AC lines
Old 04-08-2020, 05:17 PM   #1161
72c20customcamper
72c20customcamper's Avatar
I looked at them .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-25-2020, 04:04 PM   #1162
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Had the body built only to find this today Removed the cab and bed is all, and the painter took the bed again. I may be on the road next year. So long, 6 years is a 10th of my life Three guys will be on body and paint, their shop is slow too.
I went pretty deep on the dry run. Less the upper rear bed, we had the height of the moldings near nuts on both sides without trying. Props to GM, the bodies are well engineered, we made few body alterations.
One of the upper bed moldings had bow near center, so we found a happy medium and finished 1/8" off a match at the rear. The front RH door to fender matched within 1/32" where they're supposed to be, I know why, we'll get it right at build. I'm only referring to placement of the moldings, not holes drilled.
Ended up shimming the fenders of course, basic cab cushion shims. Front RH cowl panel a whopping 3/16", the RH pillar took 1/8", mix on the LH door striker, and an 1/8" shim at the RH front bed for level and straight.
For what it's worth, with new cushions etc. there's a 1" gap between the cab and the top front bed panel. It also measures 3.9" from the rear of the frame rails to the back of the bed floor. I'm interested to know what others find, partially because I need to modify brackets for a rear bumper. Distance from the rear of the frame rails to a sport bumper would be exceptional help.
The bed is crooked and the cushions shot on my C20 It measures within 2/10" at 7/10" from the cab to front bed panel, and 3.7" from frame rail to end of bed floor.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-26-2020, 02:32 AM   #1163
Stover93
Paint test on an old fender. Hugger orange vs Ford lightning blue.
Stover93 is offline   Reply With Quote
Old 04-26-2020, 07:39 AM   #1164
66clow
66clow's Avatar
Disregard the word in front of the lightning but I choose blue��
Old 04-26-2020, 08:14 AM   #1165
Daron65
With the help of my son, We installed the new power steering gear box and rag joint. Took about 2 hours. Easier than I thought it would be.
1971 Chevrolet C20, Blueprint 355. Holly Street Avenger 430HP. Turbo 350
1952 Chevrolet Deluxe. Stock. True survivor with 1 paint job
1953 Buick Special. GM 355. Just a good smooth engine.
Daron65 is offline   Reply With Quote
Old 04-26-2020, 08:43 AM   #1166
66clow
66clow's Avatar
Installed the correct lower radiator hose that clears the belt for my new ac system. Also installed a tach.
Old 04-26-2020, 08:46 AM   #1167
bowtie72
bowtie72's Avatar
Swapped my three gauge idiot light dash to the five gauge dash. Ran new copper oil pressure line. Swapped wires by the instructions on Gmc Paul’s web site. Everything works great.
1968 SWB "Little White Truck"
1972 LWB LS 4l80 "Plain Jane!!"
bowtie72 is offline   Reply With Quote
Old 04-26-2020, 10:39 AM   #1168
71CHEVYSHORTBED402
Couldn't you simplify that engine bay some? Super nice truck.
Tony
Old 04-26-2020, 10:40 AM   #1169
Chevys4life
Finally found a bench seat that was local for my old 1970 that needs to be redone. Well the hard part is over for me, now let the restoration fun begin.
Chevys4life is offline   Reply With Quote
Old 04-26-2020, 11:02 AM   #1170
rowdy11
Rear driveline installed...
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 04-28-2020, 09:56 AM   #1171
phlegm
Still Green but learning
phlegm's Avatar
Got the headers installed and the exhaust installed.
https://www.facebook.com/1414494004/...23605315547011
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 04-28-2020, 11:30 AM   #1172
BugzC10
BugzC10's Avatar
Either one will look awesome, but I prefer the Blue.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 04-28-2020, 05:19 PM   #1173
Stover93
I like both too. The orange will be easier to deal with and hide more of my body work issues so I think I’m going that way.
Old 04-28-2020, 06:49 PM   #1174
toolboxchev
Very nice looking original motor!
toolboxchev is offline   Reply With Quote
Old 04-28-2020, 10:37 PM   #1175
67C10Step
67C10Step's Avatar
Re-tubed the washer nozzles, pump run but no squirt. Tackle that at a later time. Slipped the cowl back on with a new seal. Started tearing vent doors apart for paint and new seals.
Installed rear axle bump stop for lowered suspension. Like a dummy I only ordered one and didn’t notice until I opened the box.
Discovered my vacuum advance is not working. Always something.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
