Old 04-09-2020, 03:02 PM   #1
72timemachine
Rear seat and front seat interchangeable?
Hello Square body fans,
I have an '84 dually crew cab 3+3. My front seat is shot, however, the rear is in very good condition. My questions are, can you simply switch them or are they in fact different. Are the seats the same but you would have to swap over the seat brackets?
Thanks for any help on this.
72timemachine is offline   Reply With Quote
Old 04-09-2020, 03:47 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Rear seat and front seat interchangeable?
Yes you can just swap the brackets and you're good to go. Ive done it several times
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 04-09-2020, 03:48 PM   #3
TKCR
TKCR's Avatar
Same seat, just switch the tracks from the front to the back. The rear seats always make good donors.
The only other thing that is going to be different, is your front seat is non-tilt. The rear seat does tilt. Once you take apart your seat, you will see what makes a seat tilt or non-tilt. You can make the adjustments needed or leave it.
Old 04-09-2020, 04:17 PM   #4
72timemachine
Well thank you to the both of you. Yeah, it's been such a while I forgot the rear seat does fold down, could make things interesting in a panic stop if i forget to swap that part over as well...but then again, this truck does not stop in the first place.
Old 04-09-2020, 04:25 PM   #5
TKCR
TKCR's Avatar
If you do make that change, don’t forget the hinge garnishes. They are made for tilt (top pic) & non-tilt (bottom pic).
