Old 04-19-2020, 06:41 PM   #1
johnyrrr
HEI ignition fried I think
I was trying to tidy up a little under the dash and in doing so I unknowingly separated the ignition+ that goes to my Mallory HEI . It had an old butt connector that broke when tucking up wires and I tried and tried cranking her until I looked under the dash and saw the separated wires. Anyway I did some splicing and got it back together but the truck isnt getting a spark......mostly. It did fire up for 10 seconds after cranking and poking at the Batt connection on the distributor cap but then she dies again. now it just cranks and wont fire. its like I fried something while tuning her over with no juice to the distributor. Any Ideas fellas.
johnyrrr is offline   Reply With Quote
Old 04-19-2020, 07:09 PM   #2
franken
Re: HEI ignition fried I think
Measure the voltage to the HEI with a meter to start. Check for spark.
Old 04-19-2020, 08:36 PM   #3
johnyrrr
it is not getting a spark, I am thinking that the badly connected bat+ to the coil might have messed up the module maybe?
It did fire up for a few seconds after I soldered it together and then died and want start.
Old 04-19-2020, 08:41 PM   #4
PGSigns
PGSigns's Avatar
Like frankin said first check is to measure voltage. If you have 12 volts then you can do more checks.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-19-2020, 09:30 PM   #5
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
You didn't fry the HEI by not providing power, it isn't possible. I'd venture to guess that you still don't have power. I'm betting that that wire is not carrying the current to the "BATT" connection.
~Steven
Simi Valley, CA
Old 04-20-2020, 08:52 AM   #6
johnyrrr
What check would those be since the wire is hot and I still dont have spark?
Jimmy
Old 04-20-2020, 11:03 AM   #7
cj847
cj847's Avatar
Just hotwire it. Run a jumper wire from the battery + to the B+ terminal on the distributor. (I have a 6' piece of wire with alligator clips on each end just for this purpose). If you are not getting fire after this then the problem is in the distributor.
PS> depending on how the truck is wired, you may have to disconnect it to get it to die.
cj847 is offline   Reply With Quote
