Old 04-22-2020, 10:23 AM   #1
Android04
Android04's Avatar
Tire Suggestions - Help
Good morning and hope everyone is staying healthy and safe.
So I will be running a 15x8 in the rear and a 255/60, and a 15x6 front rim. I originally considered running a 225/60 up front but I'm not sure if I will like the height of the tire compared to the rear. So the only other option Diamond Back offers would be a 215/70, and I'm afraid it will look too skinny.
Truck is a 65 SWB on air ride. I originally had 235/70 all the way around but switched to wider wheels in the back and wanted to put new whitewalls on all the way around. Thoughts, suggestions?
Am I just overthinking the height by looking at the tires off the rim?
Android04 is offline   Reply With Quote
Old 04-22-2020, 11:54 AM   #2
Clyde65
Clyde65's Avatar
Re: Tire Suggestions - Help
That 6” wheel might be a problem if you have disc brakes, go with a 7” or 8” if possible.
I run a 235/70/15 on 7” rally up front, then 275/60/15 on 8” rally in back, I have drop spindles/coils and rear airbags
Clyde65 is offline   Reply With Quote
Old 04-22-2020, 12:10 PM   #3
Android04
Android04's Avatar
I'm currently still on drums for now. Do you have a side view of your truck?
Old 04-22-2020, 01:38 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
http://67-72chevytrucks.com/vboard/s...=770801&page=3
Old 04-22-2020, 02:32 PM   #5
Android04
Android04's Avatar
Originally Posted by The Rocknrod View Post
Thanks. It doesn't seem like the 70 in the front and 60 in the rear has that big of a difference.
Old 04-22-2020, 02:38 PM   #6
pinturbo75
pinturbo75's Avatar
front is 225-70-15 on 7 inch wheel, 2 3/4 inch ww
rear is 275-60-15 on 8 inch wheel, 3 inch ww
all tires are diamondback.
1972 gmc 3500 ramp truck, 350, sm465, dana 70 rear
pinturbo75 is offline   Reply With Quote
Old 04-22-2020, 02:45 PM   #7
Android04
Android04's Avatar
Perfect! Thanks so much for the visual and beautiful truck
Old 04-23-2020, 02:31 PM   #8
SCOTI
SCOTI's Avatar
215/70 is closest to the rear by comparison.
255/8 = 31.875
31.875 x 6 = 191.25
While a 205 is closest, the 215 you mentioned is a closer match of rubber per inch of wheel width vs. the 225.
255 x 60% = 6.02" sidewall height (27.04" OD)
215 x 70% = 5.92" sidewall height (26.85" OD).
The height is slightly shorter vs. the rear but still fills the wheel opening vs an even shorter 225/60 @ 25.63" OD.
The heights are based off of calculations & will vary slightly depending on the tire manufacturer.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-23-2020, 04:28 PM   #9
Android04
Android04's Avatar
Scoti - thank you for the break down. I spoke with Diamond Back and they are sending me out the 215's and I'm sending back the 225's. I look forward to seeing this thing back down on the ground.
Old 04-23-2020, 04:42 PM   #10
SCOTI
SCOTI's Avatar
No problem.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
