Old 04-25-2020, 10:44 AM   #1
ironman3452
ironman3452's Avatar
64 1 ton panel
hello all I have a question, how can I tell what differential I have in my 64 chevy 1 ton panel, let me know , thank you all
ironman3452 is offline   Reply With Quote
Old 04-25-2020, 11:05 AM   #2
Getter-Done
Getter-Done's Avatar
Re: 64 1 ton panel
Here a link to pictures of some GM rear axles.
You can count your bolts on the cover or the chunk.
Hope this helps.
Link:https://www.randysworldwide.com/diff...tification-gm/
The early bird gets the worm,
85 Chevy K-20
Old 04-25-2020, 10:00 PM   #3
Captainfab
60-66 Nut
Re: 64 1 ton panel
If it is still original and it a Chevy, it will likely be the Eaton HO52/72. If it is a GMC it will likely be a Dana 60 or 70.
Old 04-25-2020, 10:14 PM   #4
factorystock
factorystock's Avatar
Re: 64 1 ton panel
Correct, HO 72 for 1 ton. 5.14 ratio ( only axle and only ratio ). I believe I heard the HO 52 pumpkin is interchangeable with the HO 72 pumpkin. The HO 52 is usually found with a 4.11 ratio when removed from a V8 automatic '69-'72 3/4 ton 20 series ( non dana axle ).
factorystock is offline   Reply With Quote
Old 04-25-2020, 11:21 PM   #5
ironman3452
Re: 64 1 ton panel
thanks for the help, it is the original rear end, as far as i have been told, by person who owned it before me.
Old 04-25-2020, 11:28 PM   #6
Getter-Done
Re: 64 1 ton panel
Does it look like this?
85 Chevy K-20
Old 04-25-2020, 11:38 PM   #7
ironman3452
Re: 64 1 ton panel
yes
Old 04-25-2020, 11:43 PM   #8
Getter-Done
Re: 64 1 ton panel
Here a lot of info on them.
Link:http://67-72chevytrucks.com/vboard/s...t=ho72+rebuild
85 Chevy K-20
