Old 05-11-2020, 09:15 PM   #1
gafiredog
Tires
What are the biggest tires I can put on my 86 crew cab dually, its a 2 wd, and lifted about 2-3 inches. It has 16 " alcoas, with 265/75 on them now. I wanted to put 275/70, or 285/75, but the tire guy said the rims were to narrow. any help appreciated, Thanks
Art
1975 c-10 stepper
1978 single cab dually
1987 crewcab dually
1986 crewcab single wheel
1948 anglia- (the dixie twister super gas)
gafiredog is offline   Reply With Quote
Old 05-13-2020, 08:25 AM   #2
Mike C
Mike C's Avatar
Re: Tires
285 would be fine. It is a narrower rim than recommended for that width, but so it is for your 265 as well.
I have a set of 36 12.5 16.5 Wrangler RTII (bias humvee tire) mounted on a set of 16.5" dually rims that I am going to fit on my K30. That's a 315 section width compareable tire. I had a set of 2 1/2" spacers made up for the rear to fit between the inner and outer wheels. They were made to order and they listed 2" or 3" and I wasn't sure what to get and asked about the 2 1/2". No additional charge for the custom width but I don't remember who made them now. It was harder to find the older truck setup than a newer one.
The tire guy said he thought was too narrow and when I picked them up he was surprised about how well they fit. But an independent place. The chains may not mount that up for you.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-13-2020, 04:25 PM   #3
SCOTI
SCOTI's Avatar
Re: Tires
What tire place? Local or corporate? The source makes a difference.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-13-2020, 05:09 PM   #4
sweetk30
sweetk30's Avatar
Re: Tires
255/85/16 is just over 33" tall and skinny for the drw rims .
what ever tire tho make sure they dont rub sidewalls in rear . if they do you NEED the correct spacers with the hub centric ring machined on them . this guy has good product and there real nice and correct for this exact requirement .
https://www.wheeladapter.com/
here was a k30 4x4 1ton of mine i tested 255/85/16 on a pair of rims and no spacer . its the narrow c&c axle also .
if you have a pickup box and fender flares then you have more room to play with . note how close the inner tire is to the leaf spring . looks like a lot of side wall gap at the bottom but i couldn't get my finger in there . and thats no weight extra on the flatbed .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-14-2020, 09:06 PM   #5
gafiredog
Re: Tires
it is a local tire store I use here in town.
Art
1975 c-10 stepper
1987 crewcab dually
Old 05-14-2020, 09:07 PM   #6
gafiredog
Re: Tires
Thanks for the help guys.
Art
1975 c-10 stepper
1987 crewcab dually
