Old 05-19-2020, 09:52 PM   #1
Rick Bollinger
Trans cooler lines
Has anyone used this type of fittings for their transmission? Also with the stainless tubing and compression fittings.
Thanks for your feedback
Rick Bollinger is offline   Reply With Quote
Old 05-19-2020, 11:02 PM   #2
Sheepdip
Sheepdip's Avatar
Re: Trans cooler lines
They will work as long as the final connections at both ends are hose/flex...mighty expensive though.
Sheepdip is offline   Reply With Quote
Old 05-20-2020, 12:36 AM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
I did these. Very pleased with them
https://www.advanceadapters.com/prod...-516-fittings/
Old 05-20-2020, 10:24 AM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Very cool & can't miss.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-20-2020, 12:00 PM   #5
67/Heaven
67/Heaven's Avatar
Those appear to be Swagelok fittings, rated to 10,000 psi, I used them on my brake lines, never any issues. They have a two piece ferrule make sure the small ferrule is oriented correctly. Best fitting on the market IMO
67/Heaven is offline   Reply With Quote
Old 05-20-2020, 11:22 PM   #6
Rick Bollinger
Thanks everyone for your input I think I will use them.
