Old 05-07-2019, 05:36 PM   #1
kipps
Brake and clutch pedal bushings?
The bushings are still present and intact, and the clutch and brake pedal have a relatively small amount of side-to-side play.
Is it worth replacing the bushings, or will the new ones have the same amount of play?
kipps is offline   Reply With Quote
Old 05-07-2019, 06:59 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Brake and clutch pedal bushings?
id probably leave them alone unless its causing a problem
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-24-2020, 05:11 PM   #3
Carl Spangler
Carl Spangler's Avatar
I'm replacing the clutch pedal bushings because of a super annoying squeak when using the clutch.
Should I put some grease on the new bushings or put them in dry. The original bushings (49 YO) were dry and worn but surprisingly intact.
Carl Spangler is offline   Reply With Quote
Old 08-24-2020, 05:48 PM   #4
mongocanfly
I used lithium grease on mine...the clutch was squeaking bad
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-24-2020, 05:59 PM   #5
Carl Spangler
